Home > Puma (Tdci) > Suspension and damping of the new Defender. |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Do to the front as you would do to the rear 130's have feeling's as well you know
7th Sep 2010 8:53pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Hi
i can see the colours on 3 of the springs. o/s rear is Yellow Green White o/s front is White Green Red n/s front is Yellow Green Red AndrewS - any ideas on their rating, i can't see the codes on chart? i have also searched the web, but no results BM52 |
8th Sep 2010 7:36pm |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 |
I ned to check mine again as the fronts are covored in yellow marks and I could not see anythign on the rears
9th Sep 2010 8:11am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2395 |
Road spring data
Road spring Part number Colour code 90 2 seat utility (2400 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side NRC 9448 Blue/red Rear - Passenger side NRC 9449 Yellow/white 90 2 seat utility (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB101230 Green/yellow/red Rear - Passenger side RKB101240 Green/yellow/white 90 4 seat station wagon (2400 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500290 Red/green/green Rear - Passenger side RKB500280 Red/green/red 90 4 seat station wagon (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500270 White/green/pink Rear - Passenger side RKB500310 White/green/purple LHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg) Front - Driver's side NRC 8044 White/white Front - Passenger side NRC 8045 Yellow/yellow Rear - Both sides RKB101111 Purple/brown RHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg) Front - Both sides NRC 8045 Yellow/yellow Rear - Both sides RKB101111 Purple/brown LHD 110 7 seat station wagon (3050 Kg) Front - Driver's side NRC 8044 White/white Front - Passenger side NRC 8045 Yellow/yellow Rear - Both sides RKB500300 White/green/green RHD 110 7 seat station wagon (3050 Kg) Front - Both sides NRC 8045 Yellow/yellow Rear - Both sides RKB500300 White/green/green 110 heavy duty and all 130 (3500Kg) Front - Driver's side NRC 9448 Blue/red Front - Passenger side NRC 9449 Yellow/white Rear - Both sides 78 of 1212 RKB101111 Purple/brown Puma 110" SW ............................................................. Earth first. Other planets later |
9th Sep 2010 8:43am |
