![]() | Home > Technical > dual fuel tanks |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
I thought LR used to do a dual tank system. Mike
sportman Member Since: 24 Jun 2008 Location: abu dhabi Posts: 8 ![]() ![]() ![]() |
does anyone has duel tank istalled in his defender??
thornbma Member Since: 05 Oct 2008 Location: Kazakhstan Posts: 4 ![]() ![]() |
One source of secondary tanks is here: http://www.safari-equip.co.uk/index.php?page=11
Job done I will post some picture..soon...
red Defender Member Since: 11 Feb 2008 Location: Cornwall Posts: 76 ![]() ![]() ![]() |
A friend of mine has a TDI 90 with the tank under the drivers seat. He bought the rear chasis members with plastic tank, from a scrap TD5 90. After some butchery (technical term) he fitted the tank as in the TD5. Fitted the filler as the TD5 and then added a fuel transfer pump. When the main tank is low he makes a switch and transfers fuel forwards. A very succesful mod as he now has a greater range than my 110.
