Home > Camping, Caravanning and Holidays > Sankey trailer - increase nose height / angle
Hectic haggis
Scotland 2015 Defender 110 Puma 2.2 SW Corris Grey
hi,
I've put boost type alloys on my Sankey and that has raised the axle height.
My naoto hitch is mounted on an NAS tow step which is lower than the rear cross member.
So the combination has exaggerated the downward slant of the front of the trailer.
I want to keep the. Tow-step arrangement and wonder how big a job it is to move the towing eye and brake piston from its position mounted above the A-frame to below it to create a more level trailer?
Am sure I have seen it done but not sure how much of a faff it is with the brake so??
(I think it's a Mk 2 (widetrack)
Any help gratefully received!
Thanks
Doug
Post #447543 19th Aug 2015 9:19pm
Can you not move the pintle to the rear crossmember, where it is designed to be, and where the trailer lunette is designed to find it?
These trailers were designed to be very stable and relatively foolproof, they're not usually improved by modifying in this way.
Moving the pintle is simple, redesigning the trailer is not!
Post #447548 19th Aug 2015 9:26pm
Hectic haggis
Thanks Blackwolf, but as I say, I want to keep the tow step arrangement.
These sankey said are regularly modified from what I've seen, so hopefully someone knows if / how this can be done Neutral
Post #447552 19th Aug 2015 9:35pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Hectic, mk1 has a folding support leg, mk2 has a fixed jockey wheel, mk3 has disc brakes and pivoting jockey wheel.
I think I've seen a picture of the towing eye being moved to the underside of the A frame, but I'm not certain how much effort it would involve in adjusting the braking effect. Nor how such a mod would be viewed by the authorities.
Moving the pintle is a better solution, even if it was a case of fitting removing as required. I run mine with an adjustable slider plate but sat low enough to clear the rear door with the pintle open, and also means I can connect/disconnect the trailer without the spare wheel stopping the pintle from opening. Runs a little nose down, but nothing massive 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #447557 19th Aug 2015 9:47pm
Hectic haggis
Thanks ROSSCO,
Just on the jockey,I was hoping to replace my fixed clamp with a pivoting one so the jockey doesn't get fouled y the spare wheel on back door.. Is this not possible on a Mk 2?
Any idea how to raise the Pinole on a slider using the NAS tow step platform?
Post #447561 19th Aug 2015 10:04pm
Rosco
Anything is possible! I considered moving the jockey wheel on mine but the brackets aren't cheap, plus the tombstone mounting plate also needs moving back (from memory). For me I find the door opens about halfway and it's enough to get the dog/pushchair in and out so parked the idea.
Using a slider plate on a NAS step won't work, aesthetically at least as the mounting plate would need to sit higher than the step. One consideration could be using old school lowering blocks on the trailer springs. Probably the route I'll go down when I finally get round to fitting my alloys. 2007 - Stornoway Grey 90 XS SW - Gone
Post #447567 19th Aug 2015 10:12pm
uncas
HH,What size tyres did you fit on the Boost alloys? just changing the wheels and fitting the same tyres won't raise the height.
Uncas
Post #447601 20th Aug 2015 7:37am
Have you read this thread?
If not, you might want to.
Post #447612 20th Aug 2015 7:51am
uncas
I've read the original post I know that I'm not the brightest button in the box but here's my take on it.
hi,
[b]I've put boost type alloys on my Sankey and that has raised the axle height.[/b] (we agree that the Sankey has 16 inch rims YES? Boost type Alloys 16 inch yes?) if the trailer rode correctly with the original wheels on why would the same size rims lift it?
I would say it's easier and possibly safer to take the NAS type step off and fit the Nato hook where it was intended to be.
Or am I missing something else and should I stop drinking coffee and go to specsavers.
Uncas
Uncas
Post #447629 20th Aug 2015 8:47am
