![]() | Home > My Defender > Jasmin a year of ownership / running updates |
Sea shells?!
^^ yep and enough sand to build a really big sandy thing
![]() The chassis are a solid and stronger chassis but as shown everything of steel will rust if not looked after and treated correctly. So second day playing and after and hour I had this: ![]() Click image to enlarge Now I did use (but not take a pic) a very good zinc rich weld through primer prior to welding the plate in place, I know it's not the best looking of welds but I'm a little out of practice with arc and as the weld penetrated and is solid I am happy. The rear crossmember assy on the Wolf is different to the civvie version and as such it has an outer plate that bolts over the crossmember, in between the two it was a little bit rusty so a very liberal covering in cavity wax before I rebuilt it along with copious amounts injected in to the chassis itself. (Hands were far too dirty for pics sorry). A quick blast over with some fresh paint to my crossmember cover made it look nice and respectable again, quick bolt on of all the bits and I got this: ![]() Click image to enlarge So for a day and a half I am very happy with the result, now back to the long list and stock piling of spares in preparation for the chassis swap some time next year ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
ChrisJ Member Since: 12 Nov 2013 Location: Warwickshire Posts: 231 ![]() ![]() ![]() |
Fantastic efforts so far, really like this.
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10940 ![]() ![]() |
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
London 52 Member Since: 21 Oct 2014 Location: Lincoln Posts: 312 ![]() ![]() ![]() |
Top class job
So the "holiday" I was ment to be leaving for has been moved right for a couple of weeks,
![]() So now that I'm at work and the boss isn't ![]() Now I had a spare sender buried in the shed, new gasket etc but when I was looking at the sender it looked rusted in and didn't look like it wanted to ever come out so the decision of a new tank was made, tank ordered, fuel lines ordered ( ![]() The sun shining and being told there is no work at 0805 I thought I might as well get it sorted so big pile of bits ready to fit, seat out...... I wonder ?? So a load of freeze and release spray a few taps with a brass punch and out it comes....bonus! All changed and a fuel gauge that works in 10min. ![]() Click image to enlarge ![]() Click image to enlarge Well after that what else to do? Move on to the V8 ? Yep silly question, until the end of the day when I had a can of stone chip in my hand, thought I would tart up the front bumper and steering guard: ![]() Click image to enlarge Now it was just a quick tart up and a new bumper is sitting in the shed but I'm guna save that for the new chassis so this will do for a few months. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Well with some fabulous weather and a service due, I thought that it's the perfect time to crack on.
![]() Click image to enlarge Full filter swap was done inside an hour including brew times, amazingly every filter was happy to undo by hand, with such nice weather I decided to rummage in the shed for my tub of diff/transfer box oil and change that as well ( one point I shall mention now as I have seen people encounter problems before, always remove the filler plug on any item prior to removing the drain plug, "dirty oil is better than no oil" ![]() With all these fluids changed I might even treat the old girl to a gearbox and even coolant change if I get a chance. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 ![]() ![]() ![]() |
for a non technical owner, is a "wolf" any landrover which was owned by the armed services ?
lovely job by the way ![]() |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
Mash...a wonderful source of knowledge about Wolfs! Cant wait to show him mine (that's my LR!), after helping so much and offering top notch advice through the buying and searching process
![]() Click image to enlarge ...if you need to know about Wolfs, call Mash! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
Cheers Fat Cog, very nice Wolf there
![]() A Wolf is the last batch of defenders purchased by the MOD, the project was codenamed Wolf, various reasons behind the name have been put forward the two main ones are: Wheel On Left Flank "We should name this Wolf as if we b ![]() The Wolf is a heavy duty 300tdi with many unique features only to itself. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5261 ![]() ![]() |
some graft going into that
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Where to start on differences? Here is a quick list of basic things, I haven't go into detail on different specs GS/FFR etc.
From front to back; Front light guards fitted as standard (exception is the BFA, this has none fitted and the sidelight is incorporated into the headlight) Heavy duty steering guard is fitted to the 90/110 (BFA has a tubular guard fitted) Jate rings fitted front and rear (recovery/lash down and even for dangling from helicopters) 24v electrics Heavy duty chassis with additional supports for the rear tub (the excessive weight picked holes in the floor prior to this) rear cross member is a totally different design with an outer plate bolted over the top Upgraded axles (110 rear axle has additional casing welded on to it as during trials they kept snapping the axle tubes) 6-way lighting switch; allows complete black out of all lights except the convoy light or convoy and sides (only used by lead vehicle) Two part doors with angled windows ROPS. Roll over protection system Originally the rear tub had straightening plates attached to the capping, a roll over bar with a single cross bar sits directly behind the driver/commanders seat attached to a rear cage system Spare wheel mounted on the side, this has gone through various changes The roof was a complete redesign due to the ROPS, a contract to a different supplier outside of Land Rover produced the hard top due to it needing extra height is was felt a fibreglass roof would be easier to construct than to modify the normal metal one Jerry can stowage the 90 can carry two cans mounted to brackets attached to the rear bulkhead, the 110 has two lockers allowing the carriage of four jerry cans (fuel cans should only be carried in the r/h/s and water in the l/h/s) NATO tow hitch and trailer socket HD / Wolf rims Brakes are AP vented fronts and disc on the rear Now this list is not everything and I will of missed some bits but as a quick rattle from the top of the head I hope it gives you an insight. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Well after a few months of luxury with my D3 I now have Jas back
![]() ![]() I had left Jas in the care of Swmbo and all was going well until she had an argument with a lump of granite, I can't blame her as some of the lanes back home like to bite cars, so the first job I had was repairing the mirror. I had wanted to upgrade to the Mud blind spot mirrors but they are out of stock on the website so Maggie has kindly donated one of her mirror glasses to enable me to reverse clearly. Before: ![]() Click image to enlarge After: ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
