Home > Puma (Tdci) > Alarm/central locking fault
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi All, my 2015my utility is starting to play up. When locking with the fob the alarm sounds twice very annoying late at night. The interior lights are on whilst driving. Tried to lock car using the key, but just bounces back so have to use the fob. Is it anything obvious? It's going back to the dealer next month for a service if all else fails. I've looked at the fuses under the seat and they all look fine.
Regards Myn. Smoke me a kipper I'll be back for breakfast.
Post #445842 13th Aug 2015 5:59pm
Quite likely that you have a faulty door switch (shorting to ground). This will keep the interior light on, and when the alarm is set the beep is tomwarn you that the system things a door is open.
Post #445844 13th Aug 2015 6:23pm
Dora
Generally the horns going twice is telling you a door is still open, this would be supported by the interior lights.
I would try the door switches as your first point of contact. Sometimes the wires break where they pass through the conduit entering the door.
Post #445845 13th Aug 2015 6:24pm
Dora
Blackwolf Beat me by a minute Thumbs Up
Post #445847 13th Aug 2015 6:25pm
Mynstral
Thanks for your replies. I'll add it to my list of jobs for the week end.
Post #445850 13th Aug 2015 6:47pm
munch90
Yes the things its doing show a miss lock so its thinking a door is open , tailgate or bonnet is open , so maybe dodgy swithch , wire to switch touching body and earthing , or bonnet switch/wiring
Post #445852 13th Aug 2015 6:52pm
