![]() | Home > Puma (Tdci) > Alarm/central locking fault |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
Quite likely that you have a faulty door switch (shorting to ground). This will keep the interior light on, and when the alarm is set the beep is tomwarn you that the system things a door is open.
Dora Member Since: 12 May 2015 Location: South East Posts: 170 ![]() ![]() |
Generally the horns going twice is telling you a door is still open, this would be supported by the interior lights.
I would try the door switches as your first point of contact. Sometimes the wires break where they pass through the conduit entering the door. |
Blackwolf Beat me by a minute
Mynstral Member Since: 14 Feb 2012 Location: Essex Posts: 119 ![]() ![]() ![]() |
Thanks for your replies. I'll add it to my list of jobs for the week end.
Regards Myn. Smoke me a kipper I'll be back for breakfast. |
Yes the things its doing show a miss lock so its thinking a door is open , tailgate or bonnet is open , so maybe dodgy swithch , wire to switch touching body and earthing , or bonnet switch/wiring
