Home > Maintenance & Modifications > Fitting A KBX Grille and Headlight Surround |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Yes it is that simple! Russell
2011MY 110 XS USW Black |
13th Aug 2015 2:36pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
The headlamp surrounds are held on by 2 screws and then the sidelight and indicator on the outer edges.
The centre grille is held on by fir tree clips on models with air con, and screws with non air con. Apparently KBX don't supply any fixings with them (as I found out) Removing the old fir trees is an absolute bitch of a job, I hate those little BAST !!! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
13th Aug 2015 4:30pm |
Oh, and I just did it to mine if you're interested...
http://www.defender2.net/forum/topic38640-45.html 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
13th Aug 2015 4:31pm |
Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744 |
The best way to get the fir trees off the grille is to tap them out from behind. If you try and lever them out from the front you'll risk scratching the paintwork.
Oh but I do agree with RRUK... Horrible little ! |
13th Aug 2015 5:19pm |
Steve W Member Since: 30 Mar 2014 Location: West Sussex Posts: 224 |
Took the grill off and used a hair dryer to heat them up as I snapped one .... Agreed horrible little fu@&£rs.....
13th Aug 2015 5:25pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
wd40 on the back of the fir trees and a piece of wood plus a hammer gets them out no problem!
13th Aug 2015 7:29pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1220 |
Fir tree fixings??
They are so cheap....just drill the tops off and replace with new..simple Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
13th Aug 2015 8:45pm |
louiskemp1 Member Since: 19 Mar 2013 Location: Norfolk Posts: 55 |
Lucky i dont have air con then
13th Aug 2015 9:49pm |
rick123 Member Since: 04 Jun 2012 Location: winchester Posts: 11 |
I have just removed all my grill fir tree clips by pushing them through using a black rubber sanding block, very easy to do
31st Mar 2019 10:00am |
