Home > Maintenance & Modifications > Fitting A KBX Grille and Headlight Surround
louiskemp1
Sorry for a relatively amateurish question, but fairly new to this defender business!
When fitting the KBX grille and headlight surround on a puma defender, is it as simple as unscrewing the old surrounds and grille and just screwing the new one on, or do you have to remove headlights also?
Thanks
Louis Bow down
Post #445807 13th Aug 2015 2:24pm
BigRuss
Yes it is that simple! Russell
2011MY 110 XS USW Black
Post #445808 13th Aug 2015 2:36pm
RRUK
The headlamp surrounds are held on by 2 screws and then the sidelight and indicator on the outer edges.
The centre grille is held on by fir tree clips on models with air con, and screws with non air con. Apparently KBX don't supply any fixings with them (as I found out)
Removing the old fir trees is an absolute bitch of a job, I hate those little BAST Censored !!! 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #445834 13th Aug 2015 4:30pm
RRUK
Oh, and I just did it to mine if you're interested...
http://www.defender2.net/forum/topic38640-45.html 2016 D4 HSE
Post #445836 13th Aug 2015 4:31pm
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
The best way to get the fir trees off the grille is to tap them out from behind. If you try and lever them out from the front you'll risk scratching the paintwork.
Oh but I do agree with RRUK... Horrible little Censored ! Mr. Green
Post #445843 13th Aug 2015 5:19pm
Steve W
Took the grill off and used a hair dryer to heat them up as I snapped one .... Agreed horrible little fu@&£rs..... Neutral
Post #445846 13th Aug 2015 5:25pm
Roy5695
wd40 on the back of the fir trees and a piece of wood plus a hammer gets them out no problem!
Post #445878 13th Aug 2015 7:29pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Fir tree fixings??
They are so cheap....just drill the tops off and replace with new..simple Thumbs Up Thumbs Up
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #445910 13th Aug 2015 8:45pm
louiskemp1
Lucky i dont have air con then Laughing
Post #445930 13th Aug 2015 9:49pm
rick123
England 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I have just removed all my grill fir tree clips by pushing them through using a black rubber sanding block, very easy to do
Post #766214 31st Mar 2019 10:00am
