Home > Puma (Tdci) > Update on oil leak 2009 Tdci Defender
mfjeep
United Kingdom 2009 Defender 110 Puma 2.4 CSW Epsom Green
Hi all,
So my oil leak is really being a pain in the ass - I think I've narrowed it down to the inlet manifold...or at least that's where it's dripping from - does anyone have an opinion on what it's likely to be? - I'm assuming I cannot get an oil leak from the manifold it'self as it's air (am I right in saying that?) - it mist be something around/behind it. The oil in the sump has no water contamination - the exhaust manifold below the inlet manifold appears clean, fuel pump bolts and vac pump have been ruled out. Looking at a schematic engine diagram there is a Core plug down there...anyone had any experience with this type of thing?
As usual your thought would really be helpful
cheers
Mike
Post #441876 31st Jul 2015 10:44am
I was just looking at your other posts to try to get more background on this.
Are you sure it is oil, not fuel? It is possible that the Pressure Control Valve on the common rail might be leaking fuel when the rail is pressurised. This makes significant mess and also might account for your stuttering symptoms.
Also, I am not sure what you mean by this...
mfjeep wrote:
...the exhaust manifold below the inlet manifold appears clean...
... since the exhaust manifold is on the other side of the block and isn't under the inlet manifold!
Post #441891 31st Jul 2015 11:19am
dgardel
Italy
Simply
it is the oil vapor recovered from the headcam cover to the inlet manifold.
it's quite normal see a little oil sweat on Puma engine in the Stainless Steel inlet pipe... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #441937 31st Jul 2015 2:00pm
mfjeep
Hi thanks for your responses, sorry I meant water manifold not exhaust
It's definitely oil.....buut just went out and took the cover off over the injectors and there is wet pooling round the base of the injectors and around the bolt heads. Now, it could be because I washed it of with gunk on Monday - but she's been run quite a lot of longish journeys since then so I would Have thought the water would have evaporated by now. So I'm thinking rocker cover gasket - how would that fit the symptoms already mentioned?
Once again - really do appreciate your help guys
Mike
Post #442028 31st Jul 2015 8:28pm
Otis90
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Galway Green
tdci 2.4 intake manifold
Hi, did you ever get to the bottom of this? I had a small leak from the single gasket last year which I replaced but it looks to be a lot more leaking on the engine side. Its like oil but more liquid and definitely black. Its been leaking down, not loads but enough to notice. Is it fuel mix in the manifold that's leaking out? All I know is I checked the other side of the engine and all dry. Defender owner since 2007
2003 90 td5 'Otis'
2010 110 puma 'Rocky'
Post #716981 10th Jul 2018 8:16am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Rocker gasket, inlet manifold gaskets, injector seals in the rocker, and the round O ring on the inlet,
These all go rock hard over time as they are all rubber.
I did mine recently, like you I had a really nasty oil leak that ended at the bell housing,
Every gasket I removed was either cracked or shrunk.
Change them all on the top end, and your problems will be solved,
Easy job to do Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #716986 10th Jul 2018 9:27am
Otis90
Thanks for that. Ordered a few bits and give it a go. Thumbs Up Defender owner since 2007
2003 90 td5 'Otis'
Post #716989 10th Jul 2018 10:23am
