Home > Puma (Tdci) > rear wheel arch inserts
l would like to know if anyone has bought or made some rear inner wheel arch mouldings to protect the inside of the wheel arch from mud, stones, salt - bit like the front wheel arch inserts on the front of a td5 or tdci?
the company entreq has just brought out these http://www.entreq.de/products/protection/r...leche.html
but I'd like something that goes right around the inner arch but still allows articulation ... anyone seen anything or made their own ?
Post #38796 22nd Aug 2010 5:31am
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I always wondered if you could alter a set of the front liners, to fit the rear?
Post #38931 23rd Aug 2010 11:45pm
MK
IIUC I glued some high density foam (camping mattress 3/4 cm) into the inner panels. End of sudden chips hiting the aluminium. So far 15kkm including 2000 km of dusty-stony-muddy roads. Puma 110" SW
Post #38932 24th Aug 2010 3:08am
two good ideas...
I bought some 1.5mm thick plastic sheet and a rivnut tool ...
I am also looking at other vehicles, range rover (with similar sized wheels), to see if they have liners that could be adapted.
Post #38938 24th Aug 2010 6:02am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Friend painted the inside of the guards with this stuff. Basically forms a plastic liner when hardened. Worked a treat.
http://www.rhino.net.au/ute-liner.html 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #38942 24th Aug 2010 7:12am
