Home > Technical > Losing drive/speed but able to increase engine revs!
BigRuss
So I got my defender back after being in the garage for 5 weeks (long story) while it was their it was services and a leaking pinion seal on the front diff was replaced (must have been a tiny leak as there is no signs of oil).
So after having it at home and not driving it for more than 10 minutes a day until yesterday all was fine. Then the wife decided to drive it back to her parents (180 mile trip). After 20 minutes she lost power and couldn't get it over 45mph. The garage came out and claimed it was because she was in low box!
Then 20 minutes later it happens again as she was over taking a lorry on the M4 (11 month old daughter in the back!).
The RAC man can out and said straight away I can hear something binding in the drivetrain/transmission and called a low loader to toe it in Evil or Very Mad
What do we think it is?????
P.s. It went to the garage for body work and a service only it was running fine.[/s] Russell
2011MY 110 XS USW Black
Post #440060 24th Jul 2015 8:21am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
if its been stood a while could the handbrake be stuck on a bit? difflock been in?? wont have done it much good driving around with that in?
or maybe the clutch has gone, hence the reason it revs (im guessing in gear) but doesnt go any quicker...
sorry i cant be of more help, im sure someone will be along soon with some more suggestions.
Post #440066 24th Jul 2015 9:07am
BigRuss
The diff isn't locked, but I was starting to think about the hand brake.
It seems to be an intermittent problem that only happens after it's been running for a while, as if something is getting too hot and expanding and causing it to bind somewhere. The clutch is probably slipping like no tomorrow as well now. Russell
Post #440072 24th Jul 2015 9:29am
Roy5695
maybe even a seized brake caliper? but then id expect the vehicle to vier to one side all the time... but that would not disable you from going over 45mph.
Post #440073 24th Jul 2015 9:31am
BigRuss
No it doesn't vier to one side, it first happened when being driven at 60 and then again when at 70! Russell
Post #440075 24th Jul 2015 9:34am
munch90
Handbrake is not a uncommon problem after a run , but if any brake binding they should be getting hot if binding and maybe a smell from them
One thing i had a while ago was pedal sticking down a bit , and that only happen after a run , might be worth trying if you can pull brake pedal up at all , when i done it there was a load click and all been fine
but if your putting your foot down and revs going up without changing gear and no increase in speed the clutch is slipping, that could be a actual clutch probem or hydraulic problem
Post #440201 24th Jul 2015 6:08pm
BigRuss
so they garage was insisting that the issue was with the de-tent spring on the transfer box gear lever. but surprise surprise it hasn't fixed it, they now think that there is an internal issue with the transfer box. Its done 50K miles and was fine before it went in! Russell
Post #440311 25th Jul 2015 11:44am
ARC99
A main dealer service used involve making sure that the gearbox was fully functioning, from my experience some fitters do not know how to obtain low box or lock the diffs, they believe that they can do it without the use of the clutch believing that that part is an auto box. It may worth checking the garage procedure's for checking the gearbox. Don't make old people mad.
Richard
Post #440318 25th Jul 2015 12:47pm
wyvern
sorry to here that Russ... Rosco and I are hoping it gets fixed for you
Thumbs Up
(Heather chapter of Def2.net !) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #440324 25th Jul 2015 1:59pm
BigRuss
The Heather..... It's be 4 years since I was last out there! Russell
Post #440333 25th Jul 2015 3:45pm
My ice 110 will be up for sale soon if you fancy a left hand drive
Post #440338 25th Jul 2015 5:45pm
Are you sure this isn't clutch slip or the gearbox output shaft splines?
Post #440365 25th Jul 2015 8:48pm
CRC@LandRover
Verified Account
Verified Account
Hi BigRuss
Thank you for your post.
I am sorry to learn of your vehicle concerns, please accept my apologies for any inconvenience or frustration that may have been caused.
Are you able to confirm if the investigating garage are a Land Rover approved retailer?
If this is not the case and you wish for Land Rover to look into the concerns with your vehicle, may I suggest visiting an approved Land Rover retailer.
Alternatively, should you wish for me to contact a retailer on your behalf to discuss bringing your vehicle in for inspection, please make me aware and I will be happy to assist.
Please PM me with your vehicle and contact details should you wish for me to assist.
Regards
Ryan
Post #440640 27th Jul 2015 10:34am
BigRuss
You have a PM Ryan Russell
Post #440659 27th Jul 2015 11:34am
BigRuss
So I now have it back from the garage.
After replacing the de-tent spring, Replacing the oil (and checking for metal) the issue was discovered as the gear selector rid not being set properly. There was no sign that it had moved since it was set at the factory. It just took 5 year and 51k miles to become apartment and coincidently I had had a bad experience with a garage I'd been using problem free for almost 2 years. Russell
Post #441522 29th Jul 2015 8:24pm
