BigRuss wrote:
So I now have it back from the garage.
After replacing the de-tent spring, Replacing the oil (and checking for metal) the issue was discovered as the gear selector rid not being set properly. There was no sign that it had moved since it was set at the factory. It just took 5 year and 51k miles to become apartment and coincidently I had had a bad experience with a garage I'd been using problem free for almost 2 years.
how would a gear lever issue cause it too rev up and not speed up ?
