![]() | Home > Maintenance & Modifications > Fitting an automatic gearbox |
windymiller Member Since: 03 Oct 2013 Location: farnham Posts: 223 ![]() ![]() |
2Hooky
My old 11 plate Defender has been converted and im sure you will be able to come up and have a drive as i am only just over an hour away from you . pm me if you would like to organise this. |
So answering my own question - I've just read this piece in Autocar: http://www.autocar.co.uk/car-review/land-r...110-review Their comments on the gearbox are very disappointing: "the gearbox often hunts for gears and is noticeably abrupt between first and second, while quick applications of throttle results in substantial transmission shunt when stepping-off." and "All the same, a brutish shift between first and second is just one of the ways in which the transmission can try to pour cold water on the fun." http://www.dailypost.co.uk/news/motoring/c...d-10892907 Last edited by Supacat on 16th Feb 2016 11:35am. Edited 1 time in total |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8220 ![]() ![]() ![]() |
i've driven it on a 3.2 lump. Cheers
JellyBean Member Since: 02 Mar 2015 Location: Suffolk Posts: 142 ![]() ![]() |
I bought my 90SW last year with a 4 speed auto already installed. It was fine, but seemed to rev highly in all gears and I just felt the engine was calling for more gears. It was also quite noisy, in my opinion. I had the 6 speed auto installed about 1000 miles back by JE engineering, together with a tune to approx 175 bhp. The transformation is just what I wanted.
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
Can I pick someone's brains here, please.
After stripping the v8 90 down I carelessly didn't take note where the 2 wires from the auto go to. (Hp22) One for the reverse light, I think I have covered. The inhibitor wire is what I'm struggling with, which wire (to where and colour maybe) does that go to please? Thanks in advance. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
This should help
http://forum.devon4x4.com/index.php?view=t...p;id=43883 ![]() |
What were your thoughts on it? |
Very interesting! I don't think you have mentioned that before have you? Can you get some photos up of the install and share your thoughts - especially compared to the earlier 4 speed? |
Cheers Romadog, though being a dumbass, it still doesn't make sense. I need a 'big dummies guide' ![]() |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
http://forum.lro.com/viewtopic.php?f=65&t=64104
Try this Mr G |
Cheers Chris. Between the two links, I think I know where I'm at, I need get the cooling and oil cooler pipes on now and I should be ready to turn her over.
Sorry for the hijack. |
I've been wanting auto in my td5 for years any one run Td5 with compushift on here near me Essex / Kent / London cheers Chris
Hi SupaCat - no, haven't mentioned before. I'll take some shots and post later when get the chance. So far the set up has been great - definitely the right box for the 2.2 engine, but costly!
I've also had the air suspension added by ACHV, if anyone is interested. I'm in London/Suffolk should anyone want to try. Mark |
Mark - I think there's probably quite a few on here that would be more than interested to hear about the bits you have had done.
