Home > Maintenance & Modifications > Any advice on a Momo specific 48 spline boss?
Kiki
Scotland 2014 Defender 90 Puma 2.2 SW Indus Silver
I've done a search before hand, and dont seem to have come across anyone who has had the issues that i have. (I doubt thats true, more than likely im just a tumshy at searching)
I initially wanted to fit a Momo steering wheel on my 14 plate
The boss that i purchased was a Momo 5802LR and the correct 48 splines.
Fitted fine, but the problem i had was the centre cover/horn wouldnt push down and seat correctly due to there being no room as the steering wheel nut was in the road.
Through experience guys, which Momo fitment bosses give plenty clearance for the horn to fit correctly?
Look forward to your answer. Cheers,
Michael
Post #439761 22nd Jul 2015 9:35pm
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
The Springalex ones from MPS-Trading and others (all on ebay) will give about 10mm clearance.
Post #439777 22nd Jul 2015 10:07pm
Kiki
Brilliant thanks.
Anybody else know of any other tried and tested specific boss or boss & adapters which result in the perfect horn clearance? Cheers,
Michael
Post #439789 23rd Jul 2015 5:43am
Bosses from Momo can be quite hit and miss, we've had deliveries in before from Momo with 3 different sized bosses in the same batch.
It is possible to dismantle / adapt the horn push to fit if you want to go that route
Post #439791 23rd Jul 2015 6:02am
Kiki
No, its the Momo Quark i have.
Its horn is hard black plastic with brass connectors on the back. It would be impossible to take it apart. The only solution would be to take a dremel to it, and i dont want to do that.
All i need is enough room for it to fit on, and the Momo kit never allowed it enough room due to the steering wheel nut.
Ideally someone who has a Quark fitted.... which boss did you use? Cheers,
Michael
Post #439796 23rd Jul 2015 6:20am
Pretty much all the horn pushes are the same.
Yes, you'll have to take a Dremel to it but horn pushes are only pennies.
The point I was making was that we have had a batch of 5802LR bosses in and each one has been different.
I can tell you that the Optimill boss will only work with the supplied cap and you can't use your horn push at all.
Post #439800 23rd Jul 2015 6:29am
