Home > Maintenance & Modifications > Any advice on a Momo specific 48 spline boss? |
scotia Member Since: 29 Oct 2014 Location: North Cambs Posts: 96 |
The Springalex ones from MPS-Trading and others (all on ebay) will give about 10mm clearance.
22nd Jul 2015 11:07pm |
Kiki Member Since: 21 Jul 2015 Location: Fife Posts: 12 |
Brilliant thanks.
Anybody else know of any other tried and tested specific boss or boss & adapters which result in the perfect horn clearance? Cheers, Michael |
23rd Jul 2015 6:43am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
Bosses from Momo can be quite hit and miss, we've had deliveries in before from Momo with 3 different sized bosses in the same batch.
It is possible to dismantle / adapt the horn push to fit if you want to go that route |
23rd Jul 2015 7:02am |
No, its the Momo Quark i have.
Its horn is hard black plastic with brass connectors on the back. It would be impossible to take it apart. The only solution would be to take a dremel to it, and i dont want to do that. All i need is enough room for it to fit on, and the Momo kit never allowed it enough room due to the steering wheel nut. Ideally someone who has a Quark fitted.... which boss did you use? Cheers, Michael |
23rd Jul 2015 7:20am |
Pretty much all the horn pushes are the same.
Yes, you'll have to take a Dremel to it but horn pushes are only pennies. The point I was making was that we have had a batch of 5802LR bosses in and each one has been different. I can tell you that the Optimill boss will only work with the supplied cap and you can't use your horn push at all. |
23rd Jul 2015 7:29am |
