Home > My Defender > Help! Where are the speaker wires?
Joolz
United Kingdom 2015 Defender 90 Puma 2.2 CSW Keswick Green
Hi I have a new defender 90 - bought without stereo or speakers. I am now fitting Alpine and Focal units using DIN adaptor from MUD. However just cannot find speaker wires at the speaker outlets - did LR not fit them. have seen a Battersby thread where in similar situation he located wires - but I am having no luck
J
Post #438688 18th Jul 2015 7:28am
RRUK
Never assume anything is pre wired ready for upgrades later.
I had a hard top (very base spec) and you had to add it all yourself, they don't seem to fit one loom that is ready to plug it all into. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #438690 18th Jul 2015 7:39am
AndyS
When buying my 110 I initially specified a base model and one of the available upgrades was wiring for a radio. So they don't come pre-wired for a radio by default, that's an upgrade.
Post #438692 18th Jul 2015 7:54am
munch90
I would be surprised if the factory are fitting different looms between models now days
Post #438693 18th Jul 2015 8:02am
rich
England 2004 Defender 90 2.5 TD HT Barolo Black
they are usually trapped up behind the dash you will have to unscrew the grab handle to get to them couldnt tell you exactly where they are trapped but they are there
Post #438718 18th Jul 2015 10:22am
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
I fitted speakers to 2014 defender and the speakers wires were taped up under the dash left and right and I accessed the wires via the speaker blank plate.....If you put your hand up via the speaker hole you will eventually locate the connector..
Dave
Post #439252 21st Jul 2015 8:57am
