![]() | Home > My Defender > Help! Where are the speaker wires? |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
Never assume anything is pre wired ready for upgrades later.
I had a hard top (very base spec) and you had to add it all yourself, they don't seem to fit one loom that is ready to plug it all into. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 ![]() ![]() ![]() |
When buying my 110 I initially specified a base model and one of the available upgrades was wiring for a radio. So they don't come pre-wired for a radio by default, that's an upgrade.
I would be surprised if the factory are fitting different looms between models now days
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 ![]() ![]() ![]() |
they are usually trapped up behind the dash you will have to unscrew the grab handle to get to them couldnt tell you exactly where they are trapped but they are there
Dave Bellis Member Since: 21 May 2014 Location: Shrewsbury Posts: 133 ![]() ![]() ![]() |
I fitted speakers to 2014 defender and the speakers wires were taped up under the dash left and right and I accessed the wires via the speaker blank plate.....If you put your hand up via the speaker hole you will eventually locate the connector..
Dave |
