Home > In Car Electronics > Reverse Selected - Positive Feed?
Page 1 of 3 123>
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi All
In my continued enforced recuperation I've been researching double din head units and have a question reference those that have reversing camera inputs which select automatically when reverse is selected. All seem to rely on a 12v+ when reverse is selected.
So that makes the reverse lamp the most logical connection but thats a long way from the dashboard. Is there a closer take off point which is not too hard to access?
My only other thought is you've got to run the camera feed anyway so I guess running an extra cable to pick up the reverse light at the back is no real hassle?
Or am I barking up the wrong lamppost?
TIA
Barney
Post #438350 16th Jul 2015 6:19pm
munch90
Reverse light switch on gearbox is bit closer
Post #438352 16th Jul 2015 6:33pm
There is certainly no easy acess unless you go to the rear.
Personally I would go to the rear anyway and make up a small loom to add in without cutting into the standard wiring.
The parking wire if present often marked 'PRK SW' can normally be bypassed by simply putting to ground.
The reverse as you mention is 12v, either tap into the reverse as you know or use a switch.
Post #438354 16th Jul 2015 6:35pm
Barney12
Thanks guys.
Steve, your comment prompts another question.....
I'm not sure I understand what the "parking" wire is for?
I'm assuming its to prevent video/dvd playback unless parked?
Sorry car electrics are not my forte!
Barney
Post #438365 16th Jul 2015 7:16pm
That's exactly what it's for Thumbs Up
Post #438368 16th Jul 2015 7:24pm
munch90
Yes park switch wire is so you cant play dvd while driving if its in view of driver which is illegal
connects to h/brake or park switch on a automatic
as said it can be connected to earth and save running the wire to switch , but if you get caught or have a accident and they find a dvd playing your in the 5hit ( easy way is dont play a dvd while driving ! )
other option for reverse switched wire for camera would be to just fit a switch to just switch camera on when needed , also it can be used without reverse then to keep a eye on trailer etc while driving ( as far as i know thats legal , anyone know different? )
Post #438370 16th Jul 2015 7:29pm
As above that's true, although you may well find it actually effects functionality you want to use.
For example if you were towing a horsebox and you wanted a cam in the rear to keep an eye on what's going on back there the parking earth would prevent you.
Putting a DVD on or other video would be illegal though whilst driving unless it was playing audio only.
That is one issue covered, the next is the fact some vehicles handbrake wiring are live not earth as some HU's require.
For this reason many ground this wire for this very reason.
Mine is earthed, but frankly I rarely use any video anyway full stop.
Post #438371 16th Jul 2015 7:31pm
munch90
if you need to switch a earth feed to a positive or postive to earth it can be done easily with a relay
Post #438373 16th Jul 2015 7:35pm
As far as I'm aware it is, IWT sells a standalone horsebox monitor.
Page 6 here: http://www.iwt.co.uk/iwt-parts/download/142
In response to munch yes, your right you could but why when you can simply ground it. Just creating work in my opinion.
Post #438374 16th Jul 2015 7:37pm
The hand brake switch on a Defender switches an earth which is what most HU require.
It is easy to get to so no reason not to wire it correctly.
Most HU require a positive to enable the rear view camera and the Defender gear box switch switches a negative so a non starter, unless you use a relay.
We always pick up off the reversing light itself as we are running the reverse camera cable anyway but there must be a relay somewhere that controls the reversing light ???
Post #438377 16th Jul 2015 7:39pm
munch90
I know horseboxes etc have cameras in rear etc , and guess its much the same as having a dash cam with screen
Post #438378 16th Jul 2015 7:41pm
munch90
no relay on reverse light , not heavy enough load i guess
Post #438380 16th Jul 2015 7:42pm
The reverse is a dedicated load I suppose so directly live switched and fused.
Incandescent bulb would only draw circa 2.1A LED much much less.
Post #438382 16th Jul 2015 7:45pm
But the gearbox switch switches a negative so how does that switch the reverse light ?
Post #438383 16th Jul 2015 7:49pm
You can switch a live or earth, both work in the same way.
Either causes a break in the circuit, reverse selected switch engages and regular driving the circuit is broken.
Usually the earth is switched anyway as it carries no load, unlike the live.
Most items are earth switched via a relay due to the load such as aux spot lights or similar due to a fairly high load on the live.
In the reverse it's a low load so it's directly switched no relay, so a very basic circuit indeed.
It is however fused though and earth switched.
Post #438384 16th Jul 2015 7:55pm
Page 1 of 3 123>
