Home > In Car Electronics > Reverse Selected - Positive Feed?
Page 3 of 3 <123
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Yes, I'm now sold on the switch idea Very Happy
Now I'm being thick again.....Have I got this right?
So the signal wire relies on a +ve signal to activate the camera. Thus if the camera is powered from an ignition live point (I guess the same one that powers the head unit is fine) then run the +ve of the camera and the signal feel live through a single pole switch and that all works nicely?
Post #438531 17th Jul 2015 11:06am
Barney12
I know it's bad form to bump your own question but was I on the right lines with the above comment ^^^^
TIA
Barney
Post #439760 22nd Jul 2015 10:35pm
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
Yes,that would work!
I used a separate + feed for the switch as the camera-box is hidden behind the dash and it was easier to take a feed from the new fuse-box in the under-cubby storage box. The switches I use also need a ground for the built-in lights (amber/red).
Post #439833 23rd Jul 2015 10:26am
Page 3 of 3 <123
