Home > Puma (Tdci) > Power drop & brake fade (imaginary?)
Naks
Hi all,
I'm hoping this is a figment of my imagination.
Yesterday we took the landy to the sand dunes to play.
As soon as I pulled out from the driveway onto the road, I thought/imagined that there was a drop in power from 2nd gear onwards. However, the landy is still able to hit 100kmh at 2000rpm, it just seems it's taking longer to get there and I have to rev harder while going through 2nd, 3rd, 4rd & 5th.
Also, it seems that there is a lack of braking power - seems to me that I am pushing harder on the brake pedal to decelerate the landy.
There are no obvious signs that anything is wrong - no oil/fluid leaks anywhere, bonnet is clean inside, and my EMS2 is not reporting anything out of the ordinary (EGT, oil pressure, coolant level & temp).
Consumption is on par, we did 285km on half a tank, which is almost 10l/100km, although the dune climbs were being done at (almost) full throttle in 2nd high, so would worsen consumption..
So, am I imagining these symptoms or not!? Neutral
Post #38263 16th Aug 2010 4:47pm
alantd
Sounds like you've been driving another car in between Wink One that started out as a 2.4 TDCi 110 XS
Post #39172 26th Aug 2010 9:03pm
Naks
SWAMBO's A3 TDI 2.0 Rolling with laughter
Post #39185 27th Aug 2010 5:16am
