Home > Puma (Tdci) > Power drop & brake fade (imaginary?) |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
Hi all,
I'm hoping this is a figment of my imagination. Yesterday we took the landy to the sand dunes to play. As soon as I pulled out from the driveway onto the road, I thought/imagined that there was a drop in power from 2nd gear onwards. However, the landy is still able to hit 100kmh at 2000rpm, it just seems it's taking longer to get there and I have to rev harder while going through 2nd, 3rd, 4rd & 5th. Also, it seems that there is a lack of braking power - seems to me that I am pushing harder on the brake pedal to decelerate the landy. There are no obvious signs that anything is wrong - no oil/fluid leaks anywhere, bonnet is clean inside, and my EMS2 is not reporting anything out of the ordinary (EGT, oil pressure, coolant level & temp). Consumption is on par, we did 285km on half a tank, which is almost 10l/100km, although the dune climbs were being done at (almost) full throttle in 2nd high, so would worsen consumption.. So, am I imagining these symptoms or not!? |
16th Aug 2010 4:47pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Sounds like you've been driving another car in between One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
26th Aug 2010 9:03pm |
SWAMBO's A3 TDI 2.0 |
27th Aug 2010 5:16am |
