Home > Technical > Rubber window seal |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
Google your local 'plant vehicle glazier' he will have a big roll of the stuff and fit it for you too.
9th Jul 2015 11:34am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
302177 - 5mm thick glass (to chassis EA344187)
DBF500030 - 4mm thick glass (from chassis EA344187) Filler strip for both types: DBF500040 I've given the part numbers of both types of seal as although your profile shows a 200 Tdi (so should be 4mm glass), if the roof is from an earlier 110 for some reason, it may have 5mm glass. Plus having all the part numbers may help others in the future 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th Jul 2015 11:36am |
Wizard1 Member Since: 08 Jul 2015 Location: Leyland Posts: 2 |
Thanks for the swift response and the useful info cheers people
9th Jul 2015 11:43am |
No problem, welcome to the site and do stick around 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Jul 2015 11:44am |
