Home > Technical > Rubber window seal
Wizard1
United Kingdom 1993 Defender 110 200 Tdi HT Arles Blue
Rubber window seal
Does anybody know the part number for the seal surrounding the oval glass window in the side roof line above the roof gutter. You would think it wouldn't be difficult ?!!!!
Post #436682 9th Jul 2015 11:27am
Google your local 'plant vehicle glazier' he will have a big roll of the stuff and fit it for you too.
Post #436684 9th Jul 2015 11:34am
Martin
Site Admin
302177 - 5mm thick glass (to chassis EA344187)
DBF500030 - 4mm thick glass (from chassis EA344187)
Filler strip for both types: DBF500040
I've given the part numbers of both types of seal as although your profile shows a 200 Tdi (so should be 4mm glass), if the roof is from an earlier 110 for some reason, it may have 5mm glass. Plus having all the part numbers may help others in the future Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #436686 9th Jul 2015 11:36am
Wizard1
Thanks for the swift response and the useful info cheers people
Post #436687 9th Jul 2015 11:43am
Martin
Site Admin
No problem, welcome to the site and do stick around Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #436688 9th Jul 2015 11:44am
