Home > Tdi > Hot and Cold Tdi
Page 2 of 2 <12
g-mack
Shaggy you should invest in an engine watchdog! The piece of mind is great! I've seen my engine getting a bit hot without any indication from the dash gauge! I never look at dash now as I can accurately monitor temps real time! My 109 thread
my youtube channel
Post #435534 3rd Jul 2015 1:56pm
shaggydog
Do you have a pic of your set up?
As I say I'm trying to keep it all as standard as I can but if I can stick this somewhere discrete linked to a bulb on the dash may help a bit? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #435552 3rd Jul 2015 2:30pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
This is not mine. Too lazy to go out and take a picture so I just downloaded one. But it's amazing, and already saved my engine when the water pipe that runs from the thermostat to the expansion tank under the air conditioning pump was chafed through. It's called a Madman ems.
Post #436140 6th Jul 2015 4:35pm
g-mack
Think you have seen it before. Sensor is attached to back of head using existing bolt Thumbs Up
 My 109 thread
my youtube channel
Post #436166 6th Jul 2015 7:03pm
g-mack
jfh wrote:
This is not mine. Too lazy to go out and take a picture so I just downloaded one. But it's amazing, and already saved my engine when the water pipe that runs from the thermostat to the expansion under the air conditioning pump was chafed through. It's called a Madman ems.
Can that unit measure block temperature? My 109 thread
my youtube channel
Post #436167 6th Jul 2015 7:06pm
jfh
You can check it out on their website. I'm currently monitoring the following: volts, coolant level, coolant temperature, gearbox oil temperature, egt & engine oil pressure.
Post #436169 6th Jul 2015 7:11pm
shaggydog
Thanks G-mack - yes of course I have seen it I must have been having a derp moment.
Jfh, thank you for that, I quite like it but think it may be a bit too technical at this stage but will definitely keep in in mind Very Happy
I have a feeling it might be the sender so I'm going to change that first as its the only thing I haven't done so hopefully that will fix it Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #436202 6th Jul 2015 10:10pm
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
Hi All, new to the site so thought I'd stick my nose in..
Out of interest, is your truck a genuine 200, or been converted from a disco? If so, there are differences between the temp sensors from the disco to defender, often overlooked during the conversion, if it still had the disco sensor fitted it could be giving odd readings on the gauge..
Just a thought..
Browny Smile
Post #439111 20th Jul 2015 5:06pm
shaggydog
Hi Browny,
Welcome to the site Thumbs Up
Mine is a genuine factory 200Tdi so should have the correct sender in it - that said it was owned by the environment agency for many many years so thats not to say they didn't swap sensor at some point.
It hasn't been doing it as much recently now the weather has cooled off a bit but its still on my to do list. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #439177 20th Jul 2015 9:25pm
Page 2 of 2 <12
