Home > Maintenance & Modifications > dont use britpart sump plug
LR90XS2011
Last weekend serviced the landy, I had ordered a genuine service kit from a usually reputable supplier on the internet, all items arrived in LR packaging and marked LR except the sump plug that was in a blue britpart plastic bag.
As I was keen to do the job against my better judgement I used the britpart sump plug.
I oiled it before fitting and torqued it up carefully.
Anyway today when checking underneath I noticed the sump was damp in the area of the plug, on inspection I could clearly see the the rubber oring on the sump plug had deformed.
I have therefore now dropped the oil, replaced the plug with a genuine one and refilled the oil.
The britpart sump plug oring is all chewed up, I have never seen this on a removed plug before, which normally always look as good as when fitted
I would never knowingly order britpart and I will never again fit anything from them that could effect the safety or reliability of my car.
I will also be taking this up with the supplier and wish I had in the first place. DEFENDER 90 TDCI XS,
Post #434034 27th Jun 2015 2:26pm
shaggydog
Thats not good Sad
Such a safety critical part!
Let alone the potential to damage to your own vehicle from loosing oil but leaving oil on the road for motorbikes and other vehicles is never a good thing.
Would be interested to see what there response is!
Glad you got it sorted though Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #434043 27th Jun 2015 3:09pm
Criffel
United Kingdom 1994 Defender 90 300 Tdi HT Rutland Red
Should the title be amended to just say dont use Britpart? Whistle 2011 D4 Nara Bronze
2007 Discovery Rimini Red. Gone. Thanks for the memories.
1994 Defender 90 300 TDI - Galv chassis
No one warned me Land Rover are not cars but an obsession!
Post #434082 27th Jun 2015 6:13pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
To a certain extent even good o-rings can deform. Just requires the user to 'nip up' just past the wrong point and it's gone. Never liked rubber seals on the sump. Always prefer to stick to tried and tested crush washers.
Post #434084 27th Jun 2015 6:27pm
munch90
Damp patch or leaking ?
seen plenty of sump plugs with a damp patch
did you wash plug off after tightening with brake cleaner , was the oil patch from where you oiled the plug , a couple of drips will spread out when run and warmed up
As said any o ring can catch and deform
Post #434086 27th Jun 2015 6:35pm
ARC99
This thread had me thinking not about the Blue bag company but about the sump plug seal. On all my seven Land Rover product's that I have owned the sump plug has always been a copper washer. I have just been out to confirm that that is what is fitted now.
When did they start with the rubber washers? Don't make old people mad.
Richard
Post #434087 27th Jun 2015 6:38pm
munch90
Tdci onwards so 2007
transits have had them for years before that
Post #434088 27th Jun 2015 6:44pm
LR90XS2011
here is a photo of the offending item, note as previously stated I oiled it and torqued it up correctly, not had a problem with OEM which look as good as new when removed , this clearly has a rubbish seal
Post #434095 27th Jun 2015 7:10pm
Litch
Main dealer in MK managed to strip the sump thread of my 90 on the first service (factory fitted parts obviously), never went back again. ONE LIFE, GET IT!
Post #434117 27th Jun 2015 8:40pm
AlanH
Australia
I've reused the original sump plug and washer several times on my 2010 Puma (and previous Deafeners) and I never use a torque wrench.
A couple of winds of thread tape and a drop of marine gasket maker and in it goes. Never had one leak yet.
AlanH.
Post #436469 8th Jul 2015 8:26am
K9F
Buy a Femco one and you need never worry about undoing it ever again!
http://www.drainplug.co.uk/accessories.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #436470 8th Jul 2015 8:30am
I have said this before, and will no doubt say it again in the future, but I can in all honesty say that I have never encountered a Britpart component which hasn't had some kind of deficiency, not once, not ever!
I will now only use a Britpart component if I need it urgently and there simply is no alternative. In this case I will replace it as soon as possible afterwards.
I simply don't understand how this company not only survives, but thrives, on producing such borderline stuff.
Post #436476 8th Jul 2015 9:02am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
My local Dealer made me laugh a few weeks ago,
I was getting some parts, and while looking through a shiney BritPart accessory book it had a photo of their head office/warehouse.
He told me that's not the office, that's the returns department! Rolling with laughter
I can honestly say that every item I've used from them has been utter junk!
I had a set of their vented discs, 3 weeks before they warped!
How the hell do they get away with it? Shocked 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #436481 8th Jul 2015 9:12am
K9F
Because people still buy despite numerous forums being festooned with negativity about them including this one.
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #436498 8th Jul 2015 10:30am
Caterham
or because they plan to sell their car by the end of the week Rolling with laughter
Post #436525 8th Jul 2015 1:45pm
