Home > Technical > Ghost in my TD5? The central locking doors open on their own
Landydefender1
United Kingdom 2003 Defender 90 Td5 HT Rioja Red
I posted on here that I had a problem with my central locking not working and I was advised to check the fuse..... Bingo my central locking works. Well........... Kind of?
All was well until one day when I went to lock it via the fob the cental locking would not close ie it just kept popping open.
I check all the doors as in gave them a good slam and after some pressing of the fob the doors eventually locked.
We went away and on our return I was horrified to have a 'sorry I missed you' parcel note saying that my parcel 'is in your Land Rover'!??!?!
That means during my 4 days away the cental locking has decided to open all the doors?
Any help or advise would be appreciated please?
Post #433977 27th Jun 2015 9:48am
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Check the wiring looms to the doors, especially the drivers door, for damaged wiring.
It is most likely that the insulation is damaged on one or more of the wires to the drivers door and shorting to earth, (another wire shorting probably caused the fuse to blow in the first place).
Fuses don't usually blow for no reason and I would advise anyone with a blown alarm/locking fuse to to check the wiring in these places, as this is a common Defender failure (had this on my last two Defenders).
Other than that, I would check for water ingress around the alarm unit and also check the alarm unit connectors for corrosion.
Post #434001 27th Jun 2015 12:49pm
Landydefender1
Cheers for that, where is the alarm unit situated on a TD5?
Post #434406 28th Jun 2015 10:38pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
This happened to me, same as Fifty says - check the drivers door as it's the one that gets used most, my wiring inside the door frame/pillar had worked loose and had gone fairly thin and rigid due to wear, I cut out the main perished wiring and just replaced it, just pull the rubber trunking/conduit out, then gradually pull the wiring out, there's probably 10" of slack (oooer missus!) and see if anything is obvious shows up
Post #434437 28th Jun 2015 11:49pm
Landydefender1
Thank you I will look at it tomorrow.
Where's the alarm box situated just in case it's that?
Post #434445 29th Jun 2015 12:20am
Lambley
Remove the clocks binnacle, on the r/h/s of the bulkhead there's a green box with 2 plugs, that's it. It's a Lucas 10AS unit, if you do replace it then the keys etc and ecu will need to be reprogrammed to receive signals from the new one.
Post #434454 29th Jun 2015 5:09am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Don't unplug it for inspection either or it could lose its programming and you will be stuck without a working car.
Post #434673 29th Jun 2015 8:53pm
