Home > Technical > Ghost in my TD5? The central locking doors open on their own |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
Check the wiring looms to the doors, especially the drivers door, for damaged wiring.
It is most likely that the insulation is damaged on one or more of the wires to the drivers door and shorting to earth, (another wire shorting probably caused the fuse to blow in the first place). Fuses don't usually blow for no reason and I would advise anyone with a blown alarm/locking fuse to to check the wiring in these places, as this is a common Defender failure (had this on my last two Defenders). Other than that, I would check for water ingress around the alarm unit and also check the alarm unit connectors for corrosion. |
27th Jun 2015 11:49am |
Landydefender1 Member Since: 13 May 2015 Location: East Yorkshire Posts: 63 |
Cheers for that, where is the alarm unit situated on a TD5?
28th Jun 2015 9:38pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
This happened to me, same as Fifty says - check the drivers door as it's the one that gets used most, my wiring inside the door frame/pillar had worked loose and had gone fairly thin and rigid due to wear, I cut out the main perished wiring and just replaced it, just pull the rubber trunking/conduit out, then gradually pull the wiring out, there's probably 10" of slack (oooer missus!) and see if anything is obvious shows up
28th Jun 2015 10:49pm |
Thank you I will look at it tomorrow.
Where's the alarm box situated just in case it's that? |
28th Jun 2015 11:20pm |
Remove the clocks binnacle, on the r/h/s of the bulkhead there's a green box with 2 plugs, that's it. It's a Lucas 10AS unit, if you do replace it then the keys etc and ecu will need to be reprogrammed to receive signals from the new one.
29th Jun 2015 4:09am |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Don't unplug it for inspection either or it could lose its programming and you will be stuck without a working car.
29th Jun 2015 7:53pm |
