Home > Td5 > Footwells Full of Water
Page 2 of 2 <12
Screbble
That's great Lambley, thank you - and it's available in 3 colours!
I'm sure it will be one of those products that will be used for all sorts of things around the house/garden/garage too.
Cheers,
Will
Post #434191 28th Jun 2015 7:53am
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Removed the window blocks from the truck and added silicone sealant to the gaskets (windscreen type from halfords) Also added silicone sealant to the windscreen seal, I essentially added a bead of silicone to the sponge on the outside.
Gave it 30mins and then out with the hose, still a few leaks, but played with the vent flap and eventually no leaks (today).
So I think I have cured the window block leaks, and mitigated or cured the windscreen seal leak.
I need to remove the vent flaps and fit new seals to the flaps, that way I will have mitigated another leak point.
Andy
Post #434409 28th Jun 2015 9:41pm
Page 2 of 2 <12
