Home > Td5 > Footwells Full of Water |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
Removed the window blocks from the truck and added silicone sealant to the gaskets (windscreen type from halfords) Also added silicone sealant to the windscreen seal, I essentially added a bead of silicone to the sponge on the outside.
Gave it 30mins and then out with the hose, still a few leaks, but played with the vent flap and eventually no leaks (today). So I think I have cured the window block leaks, and mitigated or cured the windscreen seal leak. I need to remove the vent flaps and fit new seals to the flaps, that way I will have mitigated another leak point. Cheers Andy |
28th Jun 2015 10:41pm |
