Home > 130 > Help finding cross member and brackets.
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
Hi all.
I need to start a thread for my 130 which I will do but just need some help at the moment.
The chissis isn't as good as we hoped and it needs more work than we hoped. I need the cross members that sit behind the cab bit can't find them on the local landy spairs computer. I've borrowed one of Andrew S's pictures as it was far clearer than mine and put three arrows on it. If anyone could tell me what part names/numbers are it would be a huge help.
Many thanks Chris.
Post #431548 17th Jun 2015 7:10am
Martin
Site Admin
Anything on http://new.lrcat.com/#!/1235/674/675/130 ?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #431593 17th Jun 2015 10:31am
Rosso_NI
United Kingdom 1993 Defender 110 2.5 n/a Diesel ST Galway Green
C02005 On the lrcat number 9 is the crossmember think its identical to one in a 110CSW not sure about brackets etc. As you know i had similar issues getting correct brackets part numbers etc.
If you have no joy i can speak to my local specialist as we got to know whats what with these brackets when i was tearing my hair out for similar reasons. Thankfully with AndrewS help and pictures i was able to see at least what the brackets looked like Thumbs Up
Looking forward to seeing you build or restoration thread 1993 Defender 110 Ex Military soft top, with a long wishlist already
Post #431809 17th Jun 2015 10:44pm
MuddyChris300tdi
Thanks Martin, I will be bookmarking lrcat, I'm sure it will get used a lot. I'm with you Rosso in thinking its number nine in co2005 as well. Thankfully the brackets you had drouble with on the tub are fine, its the three to to body I need so will see how I get on.
The Mrs is out tonight so will try and get my story started, it's a bit depressing at the moment.
Chris.
Post #431820 18th Jun 2015 5:56am
Rosso_NI
No problems Chris think if you go for it and body mounting brackets you will be sorted.
As for your story get the thread started, mines still no looker but have enjoyed all the comments advice etc. and its great to look back through, in terms of how far you have come, dates work was done etc.
Waiting with anticipation Thumbs Up 1993 Defender 110 Ex Military soft top, with a long wishlist already
Post #432391 20th Jun 2015 4:24pm
