![]() | Home > 130 > Help finding cross member and brackets. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6643 ![]() ![]() ![]() |
Anything on http://new.lrcat.com/#!/1235/674/675/130 ?
Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275 ![]() ![]() ![]() |
C02005 On the lrcat number 9 is the crossmember think its identical to one in a 110CSW not sure about brackets etc. As you know i had similar issues getting correct brackets part numbers etc.
If you have no joy i can speak to my local specialist as we got to know whats what with these brackets when i was tearing my hair out for similar reasons. Thankfully with AndrewS help and pictures i was able to see at least what the brackets looked like ![]() Looking forward to seeing you build or restoration thread 1993 Defender 110 Ex Military soft top, with a long wishlist already |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 ![]() ![]() ![]() |
Thanks Martin, I will be bookmarking lrcat, I'm sure it will get used a lot. I'm with you Rosso in thinking its number nine in co2005 as well. Thankfully the brackets you had drouble with on the tub are fine, its the three to to body I need so will see how I get on.
The Mrs is out tonight so will try and get my story started, it's a bit depressing at the moment. Chris. |
No problems Chris think if you go for it and body mounting brackets you will be sorted.
As for your story get the thread started, mines still no looker but have enjoyed all the comments advice etc. and its great to look back through, in terms of how far you have come, dates work was done etc. Waiting with anticipation ![]() |
