Home > Maintenance & Modifications > Sill chequer plate - are gaskets necessary?
Page 2 of 2 <12
nitram17
custom ..... do you simply use silicone to fix your c plate....no screws or rivets .....how long has it lasted?
Post #432065 19th Jun 2015 1:34am
YOLO110
Australia
custom90steve wrote:
Silicone with mine, providing you don't want to go back to nothing there will never be a problem.
Proper application and water won't have a chance to get in at all.
If you don't use too much in event of damage it should come off to repair rather than ripping holes drilled into the body.
That is a good idea... Sikaflex would work well.
What do you 'fill' the countersunk holes with mate... cut off bolt heads? YOLO... You Only Live Once...
Post #432068 19th Jun 2015 3:13am
Used Sikaflex on other things - once you have put it on you are never getting it off again unless you use a cheesewire. Might even make more of a mess of your wing than drilling a few holes.
Post #432086 19th Jun 2015 7:47am
K9F
Agree Sikaflex is a one way process. Better to use gasket and bead the chequerplate edge with Sikaflex if required. At least you will if required have a fair chance of being able to remove it later. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #432092 19th Jun 2015 7:54am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I used this stuff
http://www.ebay.co.uk/itm/NEOPRENE-RUBBER-...1075827316
I would stick it onto the chequer plate rather than the body work (unlike Land Rover). I have taken mine off to be reannodised in black and sourced this before I started. It was an absolute pig to remove the old stuff from the sills.
Land Rover stuck it on full width for the first and last 200mm or so, then just stuck on about a 25mm strip top and bottom, but I would presume this was cost saving and it makes more sense to me to just cover the full sill. 2002 110 td5
Post #432100 19th Jun 2015 8:26am
Page 2 of 2 <12
