Home > Technical > 2.5TD / 200TDI Clocks
Page 2 of 2 <12
gilarion
A lot depends on the ambient temperature such as if it is freezing or a hot sunny day. However the average temperature of the water entering the radiator of a fully warmed up 200TDi engine is approximately in the region of 86°-88° C normal running. This temperature will rise to 91°C when pulling up a long steep incline. If towing on a long steep incline the temperature will often rise to 98° C and my advice if this happens is go easy and when you reach the top of the incline pull over and let the engine cool down a little.
A rough guide is that usually on your thermostat will be a temperature mark saying what temp it will open at. The standard fitment 200TDi thermostat will open at roughly 88 deg C.
I believe that Land Rover also fitted a thermostat that opened at 74°C for Hot Climates For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #433809 26th Jun 2015 2:15pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
I will take the advice and try a 2.5td temp switch first Thumbs Up Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #433867 26th Jun 2015 7:00pm
Page 2 of 2 <12
