Home > Puma (Tdci) > Puma 12N towing electrics
Can someone be kind enough to tell me the correct part number for the 12N (ie normal trailer) socket kit to fit a 2007 Puma 110?
I think it may be YWJ101500 but searching for this sometimes shows it as 2007 on and other times also includes TD5 post 1999. My guess would be that it fits either provided the socket is present under the mud behind the OSR wheel.
Any recommendations as to the cheapest source for the proper item would also be appreciated.
Also, can anyone tell me what make/type the connector block itself is that is used for this? The LR part is a bit pricy and I wondered about making up my own lead, anyone know if or where these connectors can be obtained?
I have traced a faulty earth problem with my existing socket to the fact that whoever fitted it (the vehicle was pre-owned) attempted to splice the trailer socket connections into the vehicle harness adjacent to the proper connector and did a thoroughly bad job! This may be the same person who fitted a soft A-bar to the front and then found that the nuts holding the front bumper on were too difficult to refit, so just left them off!
Many thanks in anticipation!
Post #37571 3rd Aug 2010 8:39am
PaulMc
Re: Puma 12N towing electrics
YWJ101500 is the correct part number for all Defenders from TD5 to date.
They're about £70 from a Dealer - http://www.rimmerbros.co.uk/Item--i-YWJ101500
I've currently got one up on eBay for a lot less than that -
Defender 12N Towing Electrics Kit NEW GENUINE YWJ101500
As for the Trailer Pickup Connector in the Loom, it's a -
Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) – HYBRID, 9-Way Female Housing, Part No. F(6195-0170)
It's mating half on YWJ101500 is a -
Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) – HYBRID, 9-Way Male Housing, Part No. M(6195-0173)
(the gender of these connectors is determined by the gender of the terminals, not the connector shell)
The above parts are just the Connector Shells, you also require Male and Female terminals in two sizes (090 and 187), plus wire seals to suit.
Full list of numbers here -
Female - http://swsct.sws.co.jp/components/en/housi...1950170dls
Male - http://swsct.sws.co.jp/components/en/housi...1950173dls
Oh, I forgot to mention, Sumitomo will want you to buy several thousand of each part Shocked
Paul. Paul.
Post #37597 3rd Aug 2010 9:37pm
Paul,
Very many thanks for your extremely helpful and comprehensive reply. I am currently "watching" your kit on Fleabay and have every intention of placing a bid in due course (provided it hasn't rocketted in the meantime).
The info on the connectors is also appreciated. Knowing what the components are might make it possible for me to obtain a sensible quantity since I am work in a relevant industry and may be able to blag some "samples".
Thanks again!
Post #37609 4th Aug 2010 9:00am
PaulMc
If you're in a relevant industry, you could also try Molex, as they make a compatible Female Connector (vehicle loom side) -
Part No 35263-0915
Drawing - http://www.molex.com/pdm_docs/sd/352630915_sd.pdf
They only make the Female Connector Shell, TPA, Front Seal, Female 090 Terminals, and Wire Seals.
They also make a compatible Male 090 Terminal, but not the Male Connector Shell and neither the Male or Female 187 Terminals.
Here's a clickable thumb of the relevant page from a previous Molex Automotive Connectors Catalogue (35263-0915 isn't shown in the current Automotive Connectors Catalogue, but is still listed if you search the Part No. on the Molex website) -
Although he doesn't sell the 9-Way Hybrid Connector, Jim Davis at Eastern Beaver does sell some of the Sumitomo DL Sealed Series Connector range, as well as 090 Male and Female Terminals, Wire Seals and Plugs (for unused ways) to suit -
http://www.easternbeaver.com/Main/Elec__Pr.../smdl.html
He also sells other Sumitomo Connectors, as well as quite a few other very hard to come-by Automotive and Motorcycle Connectors -
http://www.easternbeaver.com/Main/Elec__Pr...ctors.html
Paul.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #37625 4th Aug 2010 1:22pm
PaulMc
A bidder from Dorset has won the Kit, was that you?
. Paul.
Post #37783 9th Aug 2010 10:20am
Yup, it certainly was. A bargain, I think!
Post #37786 9th Aug 2010 11:38am
PaulMc
I got back what I paid for it so I'm happy.
I posted it to you earlier today and sent you an eBay message with the tracking details.
. Paul.
Post #37795 9th Aug 2010 2:10pm
