![]() | Home > Puma (Tdci) > Puma 12N towing electrics |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
YWJ101500 is the correct part number for all Defenders from TD5 to date. They're about £70 from a Dealer - http://www.rimmerbros.co.uk/Item--i-YWJ101500 I've currently got one up on eBay for a lot less than that - Defender 12N Towing Electrics Kit NEW GENUINE YWJ101500 ![]() As for the Trailer Pickup Connector in the Loom, it's a - Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) – HYBRID, 9-Way Female Housing, Part No. F(6195-0170) ![]() It's mating half on YWJ101500 is a - Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) – HYBRID, 9-Way Male Housing, Part No. M(6195-0173) ![]() (the gender of these connectors is determined by the gender of the terminals, not the connector shell) The above parts are just the Connector Shells, you also require Male and Female terminals in two sizes (090 and 187), plus wire seals to suit. Full list of numbers here - Female - http://swsct.sws.co.jp/components/en/housi...1950170dls Male - http://swsct.sws.co.jp/components/en/housi...1950173dls Oh, I forgot to mention, Sumitomo will want you to buy several thousand of each part ![]() Paul. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17698 ![]() ![]() ![]() |
Paul,
Very many thanks for your extremely helpful and comprehensive reply. I am currently "watching" your kit on Fleabay and have every intention of placing a bid in due course (provided it hasn't rocketted in the meantime). The info on the connectors is also appreciated. Knowing what the components are might make it possible for me to obtain a sensible quantity since I am work in a relevant industry and may be able to blag some "samples". Thanks again! |
If you're in a relevant industry, you could also try Molex, as they make a compatible Female Connector (vehicle loom side) -
Part No 35263-0915 Drawing - http://www.molex.com/pdm_docs/sd/352630915_sd.pdf They only make the Female Connector Shell, TPA, Front Seal, Female 090 Terminals, and Wire Seals. They also make a compatible Male 090 Terminal, but not the Male Connector Shell and neither the Male or Female 187 Terminals. Here's a clickable thumb of the relevant page from a previous Molex Automotive Connectors Catalogue (35263-0915 isn't shown in the current Automotive Connectors Catalogue, but is still listed if you search the Part No. on the Molex website) - ![]() Although he doesn't sell the 9-Way Hybrid Connector, Jim Davis at Eastern Beaver does sell some of the Sumitomo DL Sealed Series Connector range, as well as 090 Male and Female Terminals, Wire Seals and Plugs (for unused ways) to suit - http://www.easternbeaver.com/Main/Elec__Pr.../smdl.html He also sells other Sumitomo Connectors, as well as quite a few other very hard to come-by Automotive and Motorcycle Connectors - http://www.easternbeaver.com/Main/Elec__Pr...ctors.html Paul. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
A bidder from Dorset has won the Kit, was that you? . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Yup, it certainly was. A bargain, I think! |
I got back what I paid for it so I'm happy. I posted it to you earlier today and sent you an eBay message with the tracking details. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
