Home > Puma (Tdci) > Defender 110 rear knocking
russgreenman
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
Good afternoon,
I have recently joined this forum upon purchase of a 2010 Defender 110 crew cab county spec. I love the vehicle, and have grown very fond of it in my short time of ownership and has made a wonderful addition to my landrover driveway. However, I am experiencing some knocking from the rear over bumps in the road etc which is proving frustrating, and has caused me some concern.
I have jacked the rear wheels up individually, there is absolutely no play in the wheel bearings on either side. I have also done my best to check for play in the suspension bushes, of which I can deem to be in good form with no movement either. When the vehicle is on the ground, if one grabs the rear tub and shakes the vehicle side to side, there is a distinctive 'knocking' coming from somewhere - felt though the hands more than audible. Is this just the drive train in the rear taking up upon the slight inevitable forward/backward movement? Or am I not checking something I ought?
If anyone would be kind enough to share their thoughts upon my predicament, I would be most grateful.
Many thanks,
Russell
Post #428841 5th Jun 2015 4:17pm
munch90
possible ball joint on top of rear axle
Post #428842 5th Jun 2015 4:19pm
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Could be anti roll bar links/bushes . my puma has 4k and the rear axle ball joint is knocking Rolling Eyes
Post #428851 5th Jun 2015 5:30pm
bob neville
Had a similar issue on my TD5. The rear shock bushes had gone, only been fitted a year Shocked
Not expensive and easy to change.
As Grizz said, could also be the roll bar bushes but I think I would start with the shock bushes and go from there.
2013 Defender 90 CSW - sold
Post #428861 5th Jun 2015 6:26pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
I had a similar problem I think and it was where the body mounts to the chassis. These bolts were loose. Bolts tightened, noise gone.
Post #428863 5th Jun 2015 6:37pm
Green Machine
I had a bump-related knocking and it was the rear lower shock bushes. As Bob says, not expensive and easy to change so might be worth starting there. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #428864 5th Jun 2015 6:44pm
Put your hand on the shock top mount collars. (Top mount bolt area)
See if you can feel anything there when you rock the body too.
Check both sides to see if there is a difference.
If there is you've pin pointed your problem shocker.
If neither of those then it could be the anti roll bar bushes as mentioned above.
If you do identify a shock causing issues report back and we can go from there. Thumbs Up
Post #428872 5th Jun 2015 7:17pm
russgreenman
Dear all,
Thankyou for your kind replies. Upon further investigation on advice received here, there is not movement in either the upper or lower shock mount bushes. The anti roll bar bushes are also solid, I have been on my back under the vehicle shaking it violently and there is no movement in any of the bushes. However, I shook the vehicle whilst holding the rear of the a frame, and can discern some movement in the ball joint. Indeed, when grabbing the a frame, I can make the knocking noise by rocking the a frame up and down. The other ends of the a frame seem to be solid. Would I be correct to assume this is the cause and would best describe my symptoms?
With regard to replacement, can one purchase a unit with the bearing in? I presume a press would be involved, and whilst I have an array of workshop items to keep my farming machinery operational, I do not own a press!
Thankyou once again for your prompt replies.
Russell
Post #428874 5th Jun 2015 7:31pm
bob neville
If I was going to replace one I would be using one of these Thumbs Up
http://www.gwynlewis4x4.co.uk/product/a-fr...n-housing/
Post #428884 5th Jun 2015 7:43pm
mk1collector
Having just replaced mine I'd recommend replacing the two bolts that hold the ball joint to the arms too. And +1 for the regreaseable gwyn Lewis one above Thumbs Up Ray
My build thread
Post #428934 5th Jun 2015 10:50pm
russgreenman
Thankyou all for your replies. I have ordered one of the suggested replacements, with new bolts and bushes for the front of the a frame also. Ignorant question, can one fit these parts with the vehicle on the ground? I presume so however would hate to get it wrong?
Many thanks again,
Russell
Post #429164 7th Jun 2015 8:39am
K9F
Morning Russ,
If the link below works as it should you'll have access to the workshop manual, wiring diagrams and loads of useful information.
https://onedrive.live.com/?cid=4bc2d89c85c...171%217067
**Edit** Just checked and it does indeed still work. I downloaded all I need, that way if the link goes down you still have it all to hand.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429169 7th Jun 2015 8:54am
russgreenman
Good evening chaps.
I am pleased to announce that the replacement of the ball joint on the a frame has proved the fix my defender needed. It drives wonderfully now. Thankyou all for your kind suggestions and help.
Russ
Post #430100 10th Jun 2015 8:47pm
