Home > Puma (Tdci) > Defender 110 rear knocking |
possible ball joint on top of rear axle
5th Jun 2015 4:19pm |
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 |
Could be anti roll bar links/bushes . my puma has 4k and the rear axle ball joint is knocking
5th Jun 2015 5:30pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Had a similar issue on my TD5. The rear shock bushes had gone, only been fitted a year
Not expensive and easy to change. As Grizz said, could also be the roll bar bushes but I think I would start with the shock bushes and go from there. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
5th Jun 2015 6:26pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
I had a similar problem I think and it was where the body mounts to the chassis. These bolts were loose. Bolts tightened, noise gone.
5th Jun 2015 6:37pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
I had a bump-related knocking and it was the rear lower shock bushes. As Bob says, not expensive and easy to change so might be worth starting there. 2005 Td5 | 90 Station Wagon | Tonga Green
5th Jun 2015 6:44pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20504 |
Put your hand on the shock top mount collars. (Top mount bolt area)
See if you can feel anything there when you rock the body too. Check both sides to see if there is a difference. If there is you've pin pointed your problem shocker. If neither of those then it could be the anti roll bar bushes as mentioned above. If you do identify a shock causing issues report back and we can go from there. |
5th Jun 2015 7:17pm |
russgreenman Member Since: 05 Jun 2015 Location: Wiltshire Posts: 13 |
Dear all,
Thankyou for your kind replies. Upon further investigation on advice received here, there is not movement in either the upper or lower shock mount bushes. The anti roll bar bushes are also solid, I have been on my back under the vehicle shaking it violently and there is no movement in any of the bushes. However, I shook the vehicle whilst holding the rear of the a frame, and can discern some movement in the ball joint. Indeed, when grabbing the a frame, I can make the knocking noise by rocking the a frame up and down. The other ends of the a frame seem to be solid. Would I be correct to assume this is the cause and would best describe my symptoms? With regard to replacement, can one purchase a unit with the bearing in? I presume a press would be involved, and whilst I have an array of workshop items to keep my farming machinery operational, I do not own a press! Thankyou once again for your prompt replies. Russell |
5th Jun 2015 7:31pm |
If I was going to replace one I would be using one of these
http://www.gwynlewis4x4.co.uk/product/a-fr...n-housing/ Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
5th Jun 2015 7:43pm |
Having just replaced mine I'd recommend replacing the two bolts that hold the ball joint to the arms too. And +1 for the regreaseable gwyn Lewis one above Ray
5th Jun 2015 10:50pm |
Thankyou all for your replies. I have ordered one of the suggested replacements, with new bolts and bushes for the front of the a frame also. Ignorant question, can one fit these parts with the vehicle on the ground? I presume so however would hate to get it wrong?
Many thanks again, Russell |
7th Jun 2015 8:39am |
Morning Russ,
If the link below works as it should you'll have access to the workshop manual, wiring diagrams and loads of useful information. https://onedrive.live.com/?cid=4bc2d89c85c...171%217067 **Edit** Just checked and it does indeed still work. I downloaded all I need, that way if the link goes down you still have it all to hand. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Jun 2015 8:54am |
Good evening chaps.
I am pleased to announce that the replacement of the ball joint on the a frame has proved the fix my defender needed. It drives wonderfully now. Thankyou all for your kind suggestions and help. Russ |
10th Jun 2015 8:47pm |
