![]() | Home > Puma (Tdci) > Wobbly rear wheel - bearing fail after only 26k? |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
If I remember right, Puma's went back to the 'proper' way of doing bearings, not these silly spacers in a TD5 (though the logic was understandable to an extent).
I can bring enough to have a look on Weds? I can even bring a complete bearing pack if need be :p ... Got a couple spare packs in me shed! Wont take 10 mins ( ![]() I cant imagine LR are very generous with greasing them up in the Factory. But even so, 26k is a bit surprising! I would guess, like blackwolf mentioned, the lock nut has come undone (through a badly staked tab). |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
....and you buy the bacon!!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
Pumas have the late TD5 arrangement - a spacer between the bearings, and a single stake nut done up rather tight.
There is however no reason why you can't ditch the spacer and revert to the earlier two nut and tab washer arrangement. |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 ![]() ![]() ![]() |
Well i managed to drive it here to the Plantworx stand. Its making horrible crunchy noises but I have little choice.
I have to get back to base (9miles) and then back here again in the morning. If you can bring a repair pack down I'd appreciate it! |
Blackwolf, You are indeed correct. For some reason I thought Puma's went back to the locknut method. Just checked MicroCAT and thusly saw all the spacers.
Either way, the bearing races themselves should be the same size, so they'll do the job if its toast! Just be ruddy careful later James! |
AndyRichards Member Since: 06 Jun 2017 Location: Shropshire Posts: 1 ![]() ![]() |
Just noticed a comment on the tread saying John Richards of Hinstock near Market Drayton looks to be closing down, i am the senior partner in the company and we are very much open for business.
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
If you're going to commit to a recovery anyway may as well open it up and have a look? Just the flange removal may tell you a lot... Solved the bowel problem, working on the consonants...
The original post is two years old, so he's probably got home by now
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
![]() Well, just in case he's still wondering what to do next .... EDIT - just realised that was my thousandth post - smooth! ![]() |
