Home > Technical > Single blower speed
bifterx
United Kingdom 2004 Defender 110 Td5 DCPU Oslo Blue
Single blower speed
Just changed both wiper boxes and worm on my late td5 (what a job!) put all back together, my heater blower now only has one speed. On its 'high' sped setting I get a dribble about the same as low speed, on low speed I get nothing . Took binnacle back out and swapped wires on terminals and I got nothing at all so changed back.
Any ideas? I can't think what could have changed
Rob Disco 300TDi XS - Gone
Disco 3 SE manual - Gone 😭
Freelander 2 SE manual
Defender 110 TD5 DC
Post #426982 28th May 2015 10:15pm
K9F
Resistor pack has thrown it's hand in or a terminal on it has become detached. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #427019 29th May 2015 7:53am
bifterx
Deffo not a terminal, I messed about with it whilst the dash binnacle was out.
When you say resistor pack, there is a resistor on the mechanism or do you mean the actual lever (used to call them rheostats when I were a lad) Disco 300TDi XS - Gone
Defender 110 TD5 DC
Post #427027 29th May 2015 8:28am
K9F
Forgot yours is a TD5. The Puma has two seperate resistors 0.45 and 0.55 ohms which are switched in individually or in series dependant on fan speed selected. Embarassed
Same principle, get a multimeter and check that your potentiometer hasn't an open circuit perhaps or more likely a short circuit as it is on high speed only? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #427051 29th May 2015 10:05am
Caterham
K9F. You out there listening?
If so how you keeping? We got snow today which is more defender weather than HD but I guess you'll still be over the moon with the HD. Out with the polishing rag each night and standing back in admiration?
Speed 1 on mine packed a while back. Speed 2 also now packed in and just speed 3 left.
I'm guessing both resistors are shot and we're running a direct circuit now?
Where are the resistors - I need to swap?
Thumbs Up
Forgot to add the illumination of the speed/numbers I also intermittent. The speed control isn't intermittent just the illumination.
Post #600880 11th Feb 2017 8:02am
Caterham
not got round to fixing it yet but it would appear if I turn the a/c button on speed 2 also works ?
any thoughts
Post #616329 12th Apr 2017 2:55pm
Caterham
haven't tested it but the leads on the resistor pack had over heated.....
Post #630311 10th Jun 2017 8:52am
