![]() | Home > Technical > ABS/TC Fuse in 2012 Defender 2.2TD |
siwady Member Since: 28 May 2015 Location: Dubai Posts: 22 ![]() ![]() ![]() |
Hello there,
Can someone help me locate the ABS/TC fuse on a 2012 Defender TD4 2.2TD. I looked everywhere and couldn't really figure it out. Thanks |
Thanks for the response Dora.
I am basically trying to disengage traction control as I will be doing a lot of sand driving and TC effect the momentum of the car. Did some reading and the only way to do that is by removing the ABS fuse. I will give it a try and see what happens. Thanks again ![]() |
Dora Member Since: 12 May 2015 Location: South East Posts: 170 ![]() ![]() |
Lets us know if it works, could be a handy tip!
