Home > Technical > ABS/TC Fuse in 2012 Defender 2.2TD
siwady
United Arab Emirates 2012 Defender 110 Puma 2.2 SW Sumatra Black
Hello there,
Can someone help me locate the ABS/TC fuse on a 2012 Defender TD4 2.2TD.
I looked everywhere and couldn't really figure it out.
Thanks
Post #426890 28th May 2015 3:37pm
Dora
On my 2011 there is an anti lock brake fuse, F9, 10amp red, in the main fuse box below steering wheel and an ABS fuse in the secondary fuse box under the drivers seat, F1, 30amp green. Nothing about TC in either.
Hope that helps.
Post #426899 28th May 2015 4:32pm
siwady
Thanks for the response Dora.
I am basically trying to disengage traction control as I will be doing a lot of sand driving and TC effect the momentum of the car.
Did some reading and the only way to do that is by removing the ABS fuse.
I will give it a try and see what happens.
Thanks again Very Happy
Post #426901 28th May 2015 4:37pm
Dora
Lets us know if it works, could be a handy tip!
Post #426903 28th May 2015 4:40pm
