Home > Camping, Caravanning and Holidays > Awning lighting |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
HI, MUD do a good light, which I'm actually going to fit to my 110, they can double as a reverse light too.
here's the link.. http://www.mudstuff.co.uk/products/electri...e-s17.html |
28th May 2015 1:42pm |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 |
If you go to the bottom of the page, that is my Defender with two fitted.... 2013 Aintree Green 110 Station Wagon SX
28th May 2015 2:39pm |
Trek Overland Site Sponsor Member Since: 16 Dec 2011 Location: York Posts: 99 |
You can buy LED Strips Kits with everything you need for it to work from us. The led strip is actually adhesive so you could stick it to the mounting beam or anywhere you like in fact. £70inc for a 2m led strip.
We could also recommend the nebula light as shown here. They are fantastic lights that are IP67 rated, switched and durable. For people on a larger budget (and those who like gadgets) we also offer the very high quality Biolite NanoGrid which can spread light over a vast area with a linkage of lights. It can also charge USB items such as phones, ipads, sat navs etc Here is the NanoGrid And they can be bought from here www.trekoverland.com | 01751 430 693 | info@trekoverland.com Expedition Equipment for you and your 4x4! www.mobilestoragesystems.net | 01751 430 318 | info@mobilestoragesystems.net For all your secure storage needs! |
28th May 2015 3:00pm |
Davidej Member Since: 30 Sep 2014 Location: Devon Posts: 266 |
thanks guys. will take a look at these options over the weekend.
28th May 2015 3:52pm |
Youre welcome David.
Just found a picture of the led strip we supply. Looks really quite cool where its mounted on this vehicle. Click image to enlarge www.trekoverland.com | 01751 430 693 | info@trekoverland.com Expedition Equipment for you and your 4x4! www.mobilestoragesystems.net | 01751 430 318 | info@mobilestoragesystems.net For all your secure storage needs! |
28th May 2015 4:17pm |
Ooh like that. Is it just adhesive or is it fixed another way? Assume it will work off cigar lighter.
28th May 2015 4:21pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
do you have a link to the led strip ....? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
28th May 2015 8:25pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
I have got a set of these fitted and to be honest the are so bright the hurt your eyes, they are great if you want scene lighting and are working around the vehicle but IMO they are too bright when facing the light under the awing. As a result I got a pair of these http://www.mudstuff.co.uk/products/electri...e-s18.html they are not as bright but still produce more than enough 'awning' lighting 130's have feeling's as well you know |
29th May 2015 5:09am |
I fitted a mud stuff scene light for reversing but also for camping. Like AndrewS it's a bit too bright to sit around, so I added a led remote controller, so,I can switch on/off remotely and has a brightness 100-50-25% option .. Works a treat, I can switch on/off from anywhere about 15metres and makes wiring the light 4 soldered connections from the purple/black wires in the rear
29th May 2015 7:06am |
I like the 100 50 25 option do you have a link to the place you got the remote from, power to my lights are from the aux batteries. 130's have feeling's as well you know
29th May 2015 8:30am |
Its just a high quality adhesive stick. Its powered by 12v and we supply it wired in and with a switch so they obviously can be turned on and off when you like. www.trekoverland.com | 01751 430 693 | info@trekoverland.com Expedition Equipment for you and your 4x4! www.mobilestoragesystems.net | 01751 430 318 | info@mobilestoragesystems.net For all your secure storage needs! |
29th May 2015 10:21am |
Im afraid its not currently on our website. However if you give Clare an email at info@trekoverland.com she will be able to give you the full spec of the product and answer any questions you may have. www.trekoverland.com | 01751 430 693 | info@trekoverland.com Expedition Equipment for you and your 4x4! www.mobilestoragesystems.net | 01751 430 318 | info@mobilestoragesystems.net For all your secure storage needs! |
29th May 2015 10:24am |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
I have one of the stick on strips and attached a merit plug to it.
I mounted it to the main awning bracket(under the rope rail) and the lead goes under the tie up straps inside the cover for traveling. I've fitted a merit outlet that's mounted through the rear panel between the number plate and the number plate light. Under instruction from the cook we also have a rear mounted LED light from MUD. The switch is mounted under the number plate light extension housing. http://www.mudstuff.co.uk/products/electri...-lamp.html Both of these lights work off our second battery Cheers, Kyle. |
29th May 2015 7:28pm |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 |
We have the Ring Tent lights. http://m.gooutdoors.co.uk/ring-27-led-tent-light-kit-p195324
We have 1 inside the roof tent, and 2 stuck on the underside, which provide light 'downstairs', either with or without the annexed zipped on. You can connect several together so you only need 1 connection to your power supply, but still have separate switches. Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
30th May 2015 9:20am |
