Home > Puma (Tdci) > Rear diff guards |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 825 |
Fitted a QT guard and got it from Cheviot 4x4 - 0191 2574444
Russell. |
18th Jun 2008 11:10am |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 |
Thanks for that will try and get one
18th Jun 2008 12:50pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Mines fitted with one from OEC http://www.oec4x4.com/
Bit of a tight fit !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
19th Jun 2008 5:30pm |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 |
Why you need one as the Puma has a 6mm welded in diff pan fitted already ?
Dave |
20th Jun 2008 6:53pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Having seen the damage a rock can do - you always need them Mike
21st Jun 2008 8:50am |
Every little helps
22nd Jun 2008 10:47am |
Yep,, extra piece of mind will post up some pics of the OEC one, when i get back California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
22nd Jun 2008 11:10am |
Always need protection! Alot cheaper than sorting out the mess a rock has caused, spent all weekend avoiding large rocks in wales, 110 did really well, no water leaks from the front doors was a plus!.
23rd Jun 2008 3:20pm |
AndrewW Member Since: 25 Nov 2009 Location: saddleworth Posts: 34 |
Does anyone have advice on diff guards from the point of view of mud collection -> corrosion of the "tinny" diff casing by trapped mud?
Is there an "open" guard? i.e. made of bar elements rather than a mud-trapping plate? Need to fit 12 on 6 Mountain Rescue 110s Andy Carefully going everywhere |
28th Apr 2010 11:03am |
Why should there be a problem?
Have had two fitted on the 110 overland vehicle for years without problems. Get your vehicle clean, waxoyl it. Then put protection on. Clean it occasionally and waxoyl every 2/3 years. Just be careful about some of the aftermarket diff guards. The ones we use and supply are made in Yorkshire from 8mm galvanised steel. There again another company will sell you 2 for £25. Must be made from far eastern tin foil HTH Brendan |
28th Apr 2010 12:11pm |
Search button and "diff guards" reveals...... http://www.defender2.net/forum/topic2837.h...iff+guards http://www.defender2.net/forum/topic2093.h...iff+guards http://www.defender2.net/forum/topic1904.h...iff+guards http://www.defender2.net/forum/topic1850.h...iff+guards More on there as well.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Apr 2010 1:18pm |
Do Tescos sell 'em too then????? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Apr 2010 1:37pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8117 |
i fitted a Southdown P38 rear diff guard. Cheers
29th Apr 2010 5:28am |
