Home > Technical > 300 TDi cut out switch
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Hi
A mate of mine (whose a car trader) has just asked if an old 300 Tdi would be fitted with a cut out switch that would be tripped if the car started to over heat. Candidly I've never heard of such a thing but I suspect there's lots of people far better qualified to provide an answer here on Def2 than me Bow down
Anyone got any ideas?
Thx
TT "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #425370 21st May 2015 6:38pm
munch90
Nope never heard of one
started to overheat or overheated , there is a big difference to what could be wrong
Post #425371 21st May 2015 6:41pm
VeeTee
Netherlands
Never heard of, but it would not be hard to make it.
Plumb in an adjustable thermostat fan controller, let the controller activate a "break type" relay to cut out the fuel solenoid. Set the adjustable controller to a temperature slightly higher to the max. temperature you think the engine has to cut out. And for safety reasons, add an override switch to the relay. Cheers, Vincent
MySite
Post #425376 21st May 2015 6:51pm
jst
no there isn't one fitted as std. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #425437 21st May 2015 9:26pm
shaggydog
^^+1 No such thing fitted as standard. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #425441 21st May 2015 9:49pm
martinfiattech
This might take a bit of plumbing.
The puma / dura torque engine is fitted as standard with a thermal cut out switch. It`s on the back of the cylinder head NO 4 cylinder.
You could, if you desired some how plumb it into the cooling system, head or block area.
Then run in series thru to the fuel pump fuel cut off solenoid. When the engine over heats. The circuit is broken and it cuts out.
A bit drastic if you ask me, a warning light or buzzer would be better. To warn of low coolant level. Excuse the spelling I`am better with spanners and wires.
Post #426226 25th May 2015 7:35pm
