Home > Maintenance & Modifications > Spare Wheel Carrier?
Gunbus
Scotland 2015 Defender 110 Puma 2.2 USW Corris Grey
I am thinking of installing a spare wheel carrier as my rear door hinge is starting to sag, I assume from the weight of the wheel.
Does anyone have one installed? Are they worthwhile and if so what is a good one to buy? I don't want something that will rust easy!
Post #425306 21st May 2015 10:42am
Trek Overland
Site Sponsor
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Fuji White
We can highly recommend Mantec, Safari Equips or the Front Runner spare wheel carriers. They all take the weight of the wheel off the door which will be the reason you are having some sagging. The mantec one will open with the door however the Equip one needs to be opened and then the rear door can be opened.
You can find out more online at > http://trekoverland.com/land-rover-online-store-wheels.html
If you don't see the product you are after on there. Give Clare a ring on 01751 430 693 and she will be able to talk you through all the possible options and advise you which one will be the best for your needs.
Thumbs Up
www.trekoverland.com | 01751 430 693 | info@trekoverland.com
Expedition Equipment for you and your 4x4!
www.mobilestoragesystems.net | 01751 430 318 | info@mobilestoragesystems.net
For all your secure storage needs!
Post #425313 21st May 2015 11:39am
leeds
Well if you want a swing away wheel carrier that does not rust easily then there is only one choice.
Nakatanenga black powder coated stainless steel one available available here
It is probably the best one available in the UK and is probably the easiest one to fit as well. Thumbs Up
Available for both pre and post 2002 models and can also do a pre 2002 chassis fitted with a post 2002 door.
Brendan
Post #425314 21st May 2015 11:42am
K9F
Depends really on functionality and form. Whilst the Nakatanenga one is obviously an excellent piece of kit so are the Safari Equipment ones. I have a Safari Equipment Single Pivot and due to the simplicity and the looks I think it is the better of the two. Mine is still perfect condition and carries a very heavy wheel with no annoying rattles or squeaks. You can also rotate the head 180 degrees for two height settings.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425319 21st May 2015 11:57am
leeds
Safari Equip single pivot wheel carriers available here
However OP did state will not rust.
We supply the full range of Safari Equip wheel carriers and have one fitted and modified on one of our 110's and the SE single pivot on another.
No rust, Safari Equip wheel carrier galvanised then powder coated works.
Brendan
Post #425322 21st May 2015 12:08pm
Iain
I went with a Nak one in black from 4x4 Overlander. Great looking, quality is very obvious and really easy one person fit and as ever outstanding service from Brendan. Combined with one of the Nak gas struts on the door its a really great set up. Controlled opening and kids (and me) less likely to get caught in the door swinging about.
Maybe a bit over cautious with fitting from new to avoid deformation. But not drilling anymore holes was important to me . The NAK one just needs an exisiting rear x member hole enlarged (M8 to M10 I think).
Been on for a month now and would happily recommend. COTAG 4x4 Response
2015 XS USW Corris Grey on DF MTR's
Post #425469 22nd May 2015 6:55am
DEF
Australia 2015 Defender 90 Puma 2.2 SW Keswick Green
+1 for NAK
Post #425487 22nd May 2015 8:19am
K9F
^ + another 19 'for NAK'...... Laughing
http://www.defender2.net/forum/topic29496....+group+buy If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425490 22nd May 2015 8:23am
Gunbus
Thanks for all your advice folks. I like the idea of the single pivot, stainless would suit best. Where I stay on the west coast of Scotland it rains 98% of the time and being next to the sea makes for a saline environment Big Cry
K9F - I like the bling door hinges Thumbs Up
Post #425496 22nd May 2015 9:03am
K9F
Thanks....They too are stainless..... Thumbs Up
With regards to the Safari Equipment Single Pivot they are not stainless but do have an excellent finish that has not rusted or blemished on mine. As stated I liked the uncomplicated look too. Either way speak to Brendan, he pulled out all the stops for me on a separate rock and tree slider purchase and even went as far as personally going and inspecting suppliers stock and adding extra packaging to ensure I received a perfect example to placate my OCD tendancies.
Post #425503 22nd May 2015 9:20am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
I went for the Nak carrier too Gunbus, the stainless was a no brainier considering the amount of road salt we see up here. Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #425691 23rd May 2015 6:46am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Thumbs Up for the NAK one .. very happy with it. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #425708 23rd May 2015 8:48am
nitram17
To the newbies (like myself) ......If you have corner rear bumpers ...........and you want to keep them make sure your chosen wheel carrier will fit!
Post #426976 28th May 2015 9:44pm
Gunbus
That makes me think, I have the rear step bumper. I'll need to check if fitting a wheel carrier will require removal/modification?? Confused
Post #427004 29th May 2015 6:56am
dgardel
Italy
Thumbs Up
Watching your machine can not figure out who among us is crazier. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #427015 29th May 2015 7:28am
