Home > Td5 > Injector harness sealing
Page 2 of 2 <12
MalteseRover
Malta
Hello,
isn't the the cam cover vented into the air pipes (pre-turbo) ?
i am so happy i have rediscovered this page.. (have been looking for days now) I have a leaking cam cover gasket and not sure if i go through the hassle of doing the injector loom too. seems fine at the moment.
Any hints or advice about this job? (first time messing with the td5 engine)
Is that Loctite SI 5980 black sealant you used? I guess most silicone based sealants should be non-conductive but I am afraid of the corrosive properties of silicone in general.
Thumbs Up
joe
Post #745767 15th Dec 2018 3:04am
lightning
This is interesting, l replaced my cam cover gasket because oil was leaking down the back of the engine, and it’s never leaked a drop since.
I didn’t use any sealant, but l should have, as the first time I fitted the new gasket it didn’t locate properly in the half moon part and l had to take it all off again.
Post #745791 15th Dec 2018 11:05am
Lefty loosey
Wales 2002 Defender 110 Td5 CSW Caledonian Blue
Hi all
Do you think araldite will work for sealing the loom ? Looked at loads of different sealers.
And by reading the packet this looks like a good call.
P.s thanks for letter me join the forum it's been a great help.
Post #795219 26th Sep 2019 4:24pm
MYSTERY
if any ones looking to replace the female plug to the injector harness it ITT CANNON SLC
Post #795350 27th Sep 2019 9:50am
Page 2 of 2 <12
