Home > My Defender > The wait is finally over
Page 3 of 3 <123
L110CDL
good looking landy Jeff, love the subtle mods Thumbs Up
cheers
Clayton.
Post #484032 20th Dec 2015 8:08pm
Pickles
Jeff 8 wrote:
Does anybody know where this goes? It is an M6 nut with integral washer I found on the rear floor, but can't find anything missing. It has the same finish as the other bolts in the Puma, so should be from somewhere.
Jeff
Cow
I found something like that, it came from inside the left rear window trim, but in my case the bolt rotated within the washer,...never did find out where it came from,...apparently finding the odd bolt/screw etc is quite a normal experience with a new Defender!
Pickles.
Post #484047 20th Dec 2015 8:41pm
Jeff 8
Australia 1998 Defender 110 300 Tdi SW Chawton White
Been a while, but I finally got a tyre carrier for the rear door. I have a Kaymar on my TDi, but don't like having to open it separately each time, and have had the door with tyre shut on my back a few times, so bought a Rijidij. They open with the door then lock open and release with a lever. As I mostly open the rear door on cambered roads, this is a great feature. I forgot to take pics during the build but will take some of the fitted item soon.
Jeff
Post #814821 12th Feb 2020 8:53pm
Jeff 8
Post #814823 12th Feb 2020 8:54pm
Jeff 8
I have grown tired of lifting the Engel fridge in and out, so looked into a second battery so I could leave it in. I originally wanted one to go under the front passenger seat next to the original, but the only ones that would fit were smaller than I wanted.
I fitted this Baintech 110Ah lithium with inbuilt DC/DC charger. It fits neatly between the drawer and rear seat, and I knocked up a plate with some plugs and a fuse holder from a scrap piece. I'll add more plugs soon.
Post #951078 30th Apr 2022 7:26am
Jeff 8
Fitted some LED headlights, they seem to be all the rage. I have had a light bar and driving lights, but they are no good when you are on low beam. Cleaned seven years of dirt out while I was at it. Just waiting for it to get dark to test them.
Post #954130 31st May 2022 7:49am
Page 3 of 3 <123
