![]() | Home > Puma (Tdci) > defender 2.2 radiator hose leak |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
Bro with that roof tent and a good wind you could become a "para Landy" !
for others searching this post....it seems the leaking coolant problem is an assembly recall issue for some Landy's. Bit of a shame site admin did not pick up on this!
aus10RRW Member Since: 19 Oct 2013 Location: Aberdeenshire Posts: 20 ![]() ![]() ![]() |
I've just had the very same issue! Ended up with a temporary fix with a plastic epoxy to seal the hole and then adjusted the power steering reservoir hose clip so it didn't rub the hose any more. The 110 is now at the dealers for a warranty claim for a new hose.
Pitch in and post the links you found ![]() |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Mine was replaced on a recall it had nearly worn through. 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
