Home > 130 > lifting the rear axel
shazzy90
any help on which springs and shocks to buy ,I need to lift the rear body on my 130 camper,50mm but as it is always carring a lot of weight I need strong springs and shocks ,at the moment it has the springs with a other spring inside ,but I don't think these are strong enough,
Post #414244 6th Apr 2015 6:08pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
If it's jut the body that needs lifting, could you not just use some 50mm box section to raise the body off the chassis?
Post #414269 6th Apr 2015 7:14pm
shazzy90
I cannot do the lift of the chassis
Post #414380 7th Apr 2015 6:10am
