Home > Puma (Tdci) > My Puma is trying to de-cat itself! |
Apparently it does indeed, let's not split hairs any longer....Why not try to remove it and retain the DPF or show everyone how this can be achieved on a 2.2!
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 3rd Apr 2015 9:36am. Edited 1 time in total |
3rd Apr 2015 9:23am |
not sure about cat needed for regen temps as on a sprinter ( early one ) , the cat is 2ft behind the dpf , later one is one unit
3rd Apr 2015 9:39am |
I agree my terminology and/or explanation was not perhaps as clear as it should/could have been, but the title of the thread was and the fact it was a 2.4.......For that please accept my apologies....
Defender..... 2.4 Catalytic Convertor only (first section from the manifold)......Fairly easily removable in one complete section by removing front propshaft and crossmember (if you wish to remove it complete) or, just chop it out. 2.2 Combined DPF/Catalytic Convertor in your downpipe (first section from the manifold) but called just a DPF in Land Rover circles......Not an option at this stage but perhaps if you can find someone clever enough to reprogramme your ECU or find a replacement export ECU where the Defender does not have a combined DPF/Catalytic convertor as standard you may perhaps, possibly be able to remove it. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Apr 2015 9:47am |
double post - sorry.
3rd Apr 2015 10:51am |
Err no just wrong. Why wriggle, just call a spade a spade and move on...a 2.2 does have a cat and you said "2.2s obviously don't have cats".
Maybe mislabelling this part as just a dpf when in fact it isn't is where the mistake came from? |
3rd Apr 2015 10:53am |
yes - on a 2.2 puma land rover the cat is used to raise the active regen temps - sprinter who knows... |
3rd Apr 2015 11:01am |
Sorry I was wrong and hope my apology makes you feel better......
I know......for the sake of peace and harmony let's call it a 2.2 CAT! It is however still not removable for the purpose of this thread on a 2.2 whatever it's labelled as, and whatever it's functionality. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Apr 2015 11:31am |
BAS
can do it for race use |
3rd Apr 2015 11:36am |
If anyone was going to come up with a solution my money would have been on Pete Bell...........
Wonder how they compare before and after? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Apr 2015 12:39pm |
Maybe low tech is the way to go:
Click image to enlarge |
3rd Apr 2015 1:13pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3786 |
Ha ha ha. I can remember my Mum & Dad doing that......in the U.K. though, not in Aus!!
Pickles. |
3rd Apr 2015 8:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17475 |
I'm not sure why there appears to be a bloke standing on the chair in the background in that "heritage fireplace" photo !
3rd Apr 2015 9:51pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
he's holding the whip DEFENDER 90 TDCI XS,
4th Apr 2015 6:30am |
